En ny BNF 3D modell jeg forventer å se ganske snart hos både Smallsize og Elflight.
Plug-N-Play® version airborne in just a few minutes. All you need is a full range aircraft transmitter and receiver, a 4S 14.8V 2800mAh Li-Po battery, and a 4S Li-Po charger. Og da ser det ut som Smallsize har de på lager, sjekk her!
Litt info fra leverandør:
Horizon News: QQ's Carbon-Z Yak 54 is Shipping!
Hey guys, the Carbon Z is in stock and shipping!
This plane looks like it may just change the "foamie" forever.
I really hope Santa received my letter, because the Carbon-Z was on it!
Fulle spesifikasjoner fra Horizon her: Carbon-Z Yak 54 PNP
Here is QQ discussing the Carbon-Z with me at i-hobby!
Carbon-Z Yak 54 PNP
Key Features
Exceptionally strong and lightweight Carbon-Z airframe
High-output 25-size brushless power system installed
E-flite 60A Pro brushless ESC installed
Digital high-speed metal gear servos installed
High-performance prop optimized for precision and 3D flying
Low friction carbon rod hinges
Replaceable wings, stab, landing gear and control surfaces
Quickly disassembles for transport or storage in this box
Requires a full range aircraft transmitter, receiver, battery and charger (sold separately)
Overview
The Carbon-Z™ Yak 54 is a quantum leap in unlimited aircraft design that uses patent pending Carbon-Z construction. The brainchild of world aerobatic champion, Quique Somenzini, it comes out of the box equipped with the phenomenal brushless Q-Power system and digital high-speed servos. The combination of these high-performance components with the light weight and superb rigidity of the Carbon-Z airframe result in a 3D airplane with a 2:1 thrust-to-weight ratio that knows no limits.
Best of all, you can have this Plug-N-Play® version airborne in just a few minutes. All you need is a full range aircraft transmitter and receiver, a 4S 14.8V 2800mAh Li-Po battery, and a 4S Li-Po charger. To get the most from the Carbon-Z Yak 54, a programmable aircraft transmitter with dual rates and exponential function is recommended.
QQ speaking about the carbon-Z.
Kategorier
article_tags
- Artikkel (31)
- axi (1)
- axi 2217/16 gold line (1)
- cc (1)
- cc phoenix 25a (1)
- CMS (1)
- diverse (6)
- dymond d47 (1)
- Featured (2)
- fly (15)
- helikopter (8)
- hyperion zs 2205 (1)
- jack power (1)
- jackpower 3s 600mah 25c (1)
- jp450xp-2s (1)
- jr ds290g (1)
- Kommende artikler (6)
- mini swift (1)
- Nyheter (8)
- rcpro (1)
- Review (26)
- sebart challenger s (1)
- thunderbird 9 (1)
- xg7 (1)
Latest Articles
by oisteinDa er det bare noen få uker igjen til det skjer igjen. Velkommen alle sammen. Stevnet starter 0900 fredag 28. august 2015 og forgår som vanlig på Udduvoll Airfield i Melhus. Shakedown hele uken. Camping på Stripa. Mer info følger.
Channel: Siste nytt
27-07-15, 22:50 -
by affaTorbjørn hos TK Trading på Konnerud i Drammen har tatt inn endel Seagull modeller på lager, blant annet Seagull P47 60.size lakkert i Snafu skjema. En sånn måtte jeg jo ha til vinterwarbird og som modell når det er rufsete for de flyene jeg er litt for redd for. Her er modellene som er tatt inn!
Et par av mine favoritter ved siden av Torbjørn.
Det blir monteringstråd på denne som kan følges ved å klikke her! Ellers er disse kommet på lager som vist på bildene und...-
Channel: Siste nytt
05-01-15, 14:47 -
by xilian...
Størrelse SAE gauge No. Amps Watt 0.3 mm² AWG 22 3A 36W 0.5 mm² AWG 20 7A 84W 0.85 mm² AWG 18 9A 108W 1.25 mm² AWG 16 12A 144W 2.0 mm² AWG 14 16A 192W 3.0 mm² AWG 12 21A 252W -
Channel: Tips og triks
01-12-14, 19:33 -
by xilianDette er ikke vanlig kost på stevner i Norge, men vi klinker altså til med livefeed av WarbirdWeekend 2014.
Nå venter vi i grunn bare på at gutta i nord skal skru på kameraet, så er vi i gang.
Men det ser ut til å ta litt tid...
WBW 2014 Live Stream 403 Forbidden" />We process personal data about users of our site, through the use of cookies and other technologies, to deliver our services, personalize advertising, and to analyze site activity. We may share certain information about our users with our advertising and analytics partners. For additional details, refer to our Privacy Policy.
Blir ikke inflight bilder med mobil....
