Taylorcraft 26ccm BNF fra Smallsize.no
  • Taylorcraft 26ccm BNF fra Smallsize.no
    Taylorcraft 26 er straks klar for levering fra Hangar9, og Smallsize.no sender oss et eksemplar for review.
    Flyet skal være 99% flyklart, rett fra butikken, så dette blir ekstremt spennende å teste ut
    Hvis du har dårlig tid, og bare MÅ ha dette flyet med en gang, har dem 20ccm-utgaven på lager
    i webshopen til SmallSize.no
    Key Features
    • Comes with a Zenoah 26cc engine
    • Six Spektrum S6000 digital servos and one AR8000 Spektrum receiver pre-installed
    • Scale tubular fuselage construction, full body pilot, and UltraCote® trim scheme
    • Includes a CNC aluminum spinner and Evolution propeller
    Overview
    The Taylorcraft was one of the first affordable civilian airplanes available to pilots in America. Manufactured by Taylorcraft Aviation, the history of the Taylor brothers and their mark on aviation dates back almost seventy years. This particular Taylorcraft is a clipped wing design for better aerobatics, and features a conventional layout and fabric covering. It is a two-seat aircraft and the basic design has remained unchanged since 1936, and is still available as a personal sport aircraft today.
    Hangar 9 brings a version of this popular model in a first-of-its-kind Bind-N-Fly (BNF) version, allowing for less time building and more time flying. Featuring incredible details, an extreme level of completion and a full body pilot, pilots will be very satisfied with this exciting giant scale release. With the included Zenoah 26cc engine, six Spektrum S6000 digital servos throughout and a pre-installed AR8000 Spektrum receiver, the assembly time is cut from hours to minutes. It will take longer to charge the batteries for flight than to do what’s left of the aircraft assembly. Add the value of genuine Hangar 9 UltraCote® and this is one airplane that all giant-scale pilots will want in their hangar.
    Product Specifications
    Wingspan: 80.5 in (205cm)
    Overall Length: 63.5 in (161cm)
    Wing Area: 1150 sq in (74.5 sq dm)
    Flying Weight: 14.0 - 14.5 lb (6.35 - 6.50kg)
    Engine Size: Zenoah 26cc (included)
    Radio: 6 channel minimum DSM2 compatible transmitter
    Servos: 6 Spektrum A6000 digital servos (installed)
    Trim Scheme Colors: White (U870), Black (U874), True Red (U866), 2" Red/White Checkers (U944)
    CG (center of gravity): 3-5/8 - 4 inch (86 - 101mm) back from the leading edge at wing root
    Prop Size: Evolution 16x6 (included)
    Spinner Size: 2-1/2 inch (included)
    Recommended Battery: 5-cell NiMH receiver battery (installed)
    Flaps: No
    Retracts: No
    Minimum Age Recommendation: 14 years
    Experience Level: Intermediate
    Recommended Environment: Outdoor
    Assembly Time: 3-5 Hours
    Is Assembly Required: Yes
    Needed to Complete
    All you need is a 6+ channel DSM2-compatible transmitter.
    Kit Includes
    Manualen finner du her
    • GTI20
      GTI20 commented
      Editing a comment
      jamen er det ikke å bare bestille samme size du har nå bare i tre da.. motor å fly gikk jo greit med den...
    • syver
      syver commented
      Editing a comment
      [QUOTE=xilian;300521]Jeg sendte en forespørsel på mail til Biela samme dag du skrev innlegget ditt Syver,
      men har ikke fått noe svar.
      Pleier han vanligvis å svare på mail?
      hei har aldrig sendt dem mail.men hvis du tar kontakt med geir fleche (3w norge)som det er linket til i tidligere post får du helt sikkert hjelp.han tar jo inn biela så det bør løse seg.
    • syver
      syver commented
      Editing a comment
      biela sine egne anbefalinger til zenoha 26 er 17x8. 18x8. 17x10.
    Posting comments is disabled.
Latest Articles
  • Pilot-RC Trainer 90 ARF 20-30CC :: JC 30cc
    affa
    Treningsmodell i kjent Pilot-RC kvalitet, beregnet på nybegynnere og de som ønsker seg en stor og velflyvende modell med bensinmotor til f.eks. sleping av seilfly. Kommer i stor grad av ferdigstillelse og er trukket i original Oracover. Modellflynytt fikk tilsendt en av de aller første til test.
    09-05-13, 15:16
  • Pilot-RC Edge 540 87"
    Tertitten
    Etter en kontakt med Elefun ang. modeller som ventes inn fra Pilot,
    ble jeg veldig gearet på den nye Edgen. 87"(30%)-Edge 540-Pilot-RC Co,Ltd.
    Dette er vel en av nyhetene som kommer nå, og vi ble enige om å teste ut denne litt.
    19-10-11, 11:21
  • Gernot Bruckman yak 55 2.2m fra Autopartner.
    anders e
    Da jeg var på Arvika-treffet i August snakket jeg mye med Per fra Autopartner. Vi snakket mye om el og bensinmodeller, der i blant Gernot Bruckman yak'n som er veldig populær i Sverige. ...
    25-09-11, 21:36
  • Pilot-rc decathlon fra Autopartner
    anders e
    Jeg syns alltid at decathlon har hatt fint og litt tøft utseende. Men desverre litt for skala for meg.
    Men......... når jeg fikk se en hovrevideo på pilot-rc sin side og et bilde på Flying Giants tok jeg kontakt med Per hos Autopartner. ...
    26-05-11, 21:33
    xilian
    Key Features
    Overview
    The Taylorcraft was one of the first affordable civilian airplanes available to pilots in America. Manufactured by Taylorcraft Aviation, the history of the Taylor brothers and their mark on aviation dates back almost seventy years. This particular Taylorcraft is a clipped wing design for better aerobatics, and features a conventional layout and fabric covering. It is a two-seat aircraft and the basic design has remained unchanged since...
    10-05-11, 14:46
  • ESM Spitfire 89 - 50cc modell til test
    affa
    Redaksjonen er svært fornøyd med denne kommende testen. ESM har i det siste halvåret sluppet flere fine modeller i 50cc størrelse. Dessverre har tilgjengeligheten vært dårlig, men ankomst av stor container nærmer seg i Sverige. Elefun og Minicars stiller opp med modell og alt utstyr i denne testen.
    31-10-10, 15:30
