har en ny container på vei inn med disse.
Følgende spesifikasjoner er gitt:
- Vingespenn: 122cm
- lengde: 122 cm
- vingeareal: 500 sq.in
- vekt: 1245-1360 gram
- Motor: 2814/820 Outrunner with Airboss 45A
- Esc w/ 4S 2350 - 2700mAh LiPo battery
- Servoer: 5 channel w/ 4 sub-micro servoer og ESC
Her er litt infomasjon fra produsenten:
The third release in the Extreme Flight RC 48 inch EXP series, the MXS is rewriting the rule book on ultra aggressive 3D maneuvers! Unrivaled in pitch and yaw authority, the MXS will be the machine that introduces a whole new level of gyroscopic gyrations and insane tumbles to the hardcore 3D masses. Rock solid in all aspects of current 3D maneuvers, the MXS will give those that fly on the bleeding edge the confidence and capability to push through and break new ground in expanding the rapidly evolving 3D flight envelope.
Utilizing the same lightweight interlocking laser cut construction and carbon reinforcement as our Extra and Edge, the MXS is capable of handling the most punishing maneuvers imaginable. Available in 2 gorgeous high visibility Ultracote color schemes with matching painted fiberglass cowl, wheel pants and racing wing tips, the MXS is sure to turn heads at the flying field long before it ever leaves the ground! An airfoiled carbon fiber landing gear, tailwheel assembly and wing tube as well as a complete useable hardware package and decal set are all part of the package and insure that your MXS is finished out with the best components possible.
-Huge airfoiled control surfaces utilizing geodetic construction provide the ultimate in yaw, pitch and roll authority.
-Ships with both Side Force Generators and Scale Racing wing tips.
-Carbon fiber longerons and motor box supports add enormous strength and rigidity to the airframe, while G10/lite ply composite laminates make for a robust landing gear mount.
-One piece airfoiled molded carbon fiber landing gear and tailwheel bracket provide solid ground handling and contribute to the awesome appearance of the EXP.
-Spring loaded hatch latch provides instant access to battery tray and interior of aircraft while providing a solid attachment point for the canopy.
-2 piece wing mounts on a carbon fiber wing tube and is easily removed for transport.
-G10 elevator and rudder horn bolts on to stock servo arm to allow for insane elevator and rudder travel.
-Rudder and elevator servo mount in the rear of the aircraft and utilize a short direct drive pushrod with ball links for slop free control surface actuation.
-Removable Side Force Generators add tremendously to the effective side area of the EXP increasing rudder authority and improving knife edge and high alpha stability.
-2 gorgeous genuine Ultracote color schemes available with expertly painted fiberglass cowl and wheel pants.
-Complete hardware package and decal sheet included.
-High level of pre-fabrication allows you to get the EXP in the air in as little as 3 hours!
