Som Håvard akkurat har nevnt så har Elefun som kjent tatt inn en drøss med flotte ARF fly fra Phoenix models og ønker dermed å teste et sett her hos redaksjonen. Valget falt på en Spitfire .60-maskin. Flyet er pakkket og sendes idag med posten. Det vil bli lagt ut fortløpende en byggeblogg på forumet som vanlig.
Litt info fra produsenten:
The Spitfire is the most famous warbird and the most popular radio controlled plane. Created with the scale enthusiast in mind, this almost-ready-to-fly airplane replicates the scale outline of its full-scale counterpart with accuracy. the Spitfire is packed with scale details. Including Retract landing gear and all the hardware are included (servo wire, fuel tank, wheel/landing gear, etc). You only need to separately purchase the nitro engine and radio system, and fly.
Key Feature
• Quality materials and genuine ORACOVER covering
• Accurately-etched panel lines and factory-applied paint scheme
• Fully detailed, factory-installed cockpit, pilot and canopy
• Extremely lightweight laser-cut all-wood construction
• True-to-scale artwork
• Scale outline is enhanced by the lightweight fiberglass cowl
• 95% factory built, covered and painted
• Can be converted for electric flight
• Flies with a wide variety of engines
• Retract landing gear included
Spesifikasjoner:
• Wingspan: 1550mm (61in)
• Length: 1350mm (53.1in)
• Weight: 3200g~3400g
• Engine: 61 two stroke / 70 four stroke
• Radio: 6~9 channel - 6 servo
• Packing: 2 pcs/carton
Mitt oppsett vil bli som følger:
Phoenix model Spitfire .60 ARF
Waypoint 1136 retract servo
4 x Hitec HS-425BB server
1 x Futaba S148 servo
APC 12x7 prop
Spektrum AR6200 RX
1100mah JR NiCd mottakerpakke
Motoren vil bli en MDS .68 motor
Linker:
Fly: Siden finnes ikke
http://www.phoenixmodel.com.vn/index...products&id=53
Key Feature
Spesifikasjoner:
APC 12x7 prop
Spektrum AR6200 RX
Linker:
