JR XG11 fra Elefun
  • JR XG11 fra Elefun
    Ryktene har versert en stund men nye JR XG11 nærmer seg faretruende og min er allerede bestilt etter å ha blitt veldig glad i XG8 radioen.
    Kommer tilsvarende artikkel på denne som XG8 med pros and cons.
    Her er noen foreløpige fakta tatt fra JR sin Facebookside:
    • DMSS Telemetry function
    • Analog trim version has a new line-up
    • XG11 transmitter has become a common for Heli and Acro.
    • Batteries for TX is LiFe(2F 1400 6.4V 1400mAh) and TX is included in charging circuit.
      DC jack is same as XG8.
    • My List
    • Easy setting function(Wizard)
    • Touch select function (You can select the display icon by hopping switch, too.)
    • Advanced digital trim
    • Trainer jack
    • SD card slot
    • Graphic display with backlight function
    • Stick sping adjust
    • Throttle stick angle adjuster(Digital version : Enclosed. Analog version : Installed)
    • Short stick head for better operation (Red color anodized stick) Option short stick head can be used.
    [System List]
    • MODEL SELECT
    • MODEL COPY/ERASE
    • TYPE SELECT
    • MODEL NAME
    • FLIGHT MODE NAME
    • TRIM SYSTEM
      *[HELI]
      [NORM] is added into Throttle trim in Digital trim version, same as XG8
      *[GLID] [FRPN] Direction of Flapperon trim is added, same as XG8
    • STICK POSITION SW * Upgrade is under study
    • TRIM INPUT SW * 4 genealogy, same as XG8
    • STICK ALERT * , same as XG8
    • WARNING
    • DEVICE SELECT
      * Trim(momentry, 2pcs & 3 position function) are added in Input divice.
      [HELI] SWASH TYPE
      [ACRO] [GLID] WING TYPE
    • TX SETTINGS
      * ①Idle alert is added, same as XG8
      * ②ON/OFF new function for Model link
    • TRAINER * SW Select is added(Trainer SW/LTRIM/RTRIM)
    • THRO STICK DIRECTION * New function from 11X Zero/DSX11
    • ALL SERVO HOLD
    • STICK MODE * New function from 11X Zero/DSX11
    • BIND & RANGE * , same as XG8
    • TELEMETRY * , same as XG8
    • FAIL SAFE
    ●COMMON
    • D/R & EXP
      * POS is extended to 8 genealogy.
      POS can be changed at stick postion switch.
      (6pcs. of SW SEL is added)
      DELAY can be set up at 8 type at POS change.
    • TRAVEL ADJUST
    • LIMIT ADJUST
    • SUB TRIM
    • REVERSE SW
    • SERVO SPEED
    • PROGRAM MIX1-6
      * ①P.MIX1-3 is not only normal fix but also curve, same as XG8
      * ②Curve can be set up at 5 points in the middle.
      (For DSX11, the curve has just 5 points but XG11 has 7 points, instead.Also, in the middle, the point is only 3 for DSX11 but XG11 has 5 points).
    • TIMER
    • MIX MONITOR
    • SERVO MONITOR
    ●HELI
    • THROTTLE CURVE * Curve can be set up at 5points in the middle.
    • PITCH CURVE * Curve can be set up at 5points in the middle.
    • TAIL CURVE * Curve can be set up at 5points in the middle.
    • THROTTLE HOLD
    • GYRO SENS
      * ①New set up function for TAGS01.(In the Gyro icon, DSX11 has only 2 selction, but XG11 has 3selection.
      In the new selection, you can see Triple Axisdisplay icon and you can set up TAG01 adjustment in this icon.)
      * ②Trim input can be made, same as XG8
    • GOVERNOR * Trim input can be made, same as XG8
    • SWASH MIX
      * ①PIT->AILE->ELEV MIX correction new function, same as XG8
      * ②E-Ring gain new fuction, same as XG8
      * ③AILE->ELEV, ELEV->AILE trim input new function are added.
    • THROTTLE TRIM
    • MIX to THROTTLE
    • FLIGHT MODE DELAY
    ●ACRO
    • THROTTLE CURVE *Curve can be set up at 5points in the middle.
    • PITCH CURVE *Curve can be set up at 5points in the middle.
    • THROTTLE HOLD
    • GYRO SENS
    • THROTTLE TRIM
      * [ACRO] IDLE ADJ. to be extended to 2 genealogy is studied(New).
    • FLAP SYSTEM * Trim input fuction is reinforced.(same as XG8
    • SNAP ROLL
      * SNAP ROLL ON/OFF can be selected by not only Snap roll switch but also trim lever.
      Stick ON/OF remains unchanged.
    • DIFFERENTIAL * Trim input function(same as XG8
    • AILE -> RUDD MIX
    • AILE -> FLAP MIX
    • ELEV -> FLAP MIX
    • RUDD -> AILE/ELEV MIX
      * ①Trim input fuction(same as XG8
      * ②Curve MIX function-up is studied.
    • BALANCE * New function
    ●GLID
    • DIFFERENTIAL
    • AILE -> RUDD MIX
    • BALANCE
      (This is also new function, like DSX12. Although DSX12 is just fixed point, XG11 has multi-point.)
    • FLAP RATE
    • MOTO SYSTEM
    • CAMB SYSTEM
    • BRAKE SYSTEM
      * Trim input function is reinforced
    • FLAPRON MIX
    • ELEV -> CAMB MIX
    • RUDD -> SP01 MIX
ID:	583526Click image for larger version
ID:	583527Click image for larger version
ID:	583528Click image for larger version
      JR har bestandig vært mitt merke men har nå en periode jeg er i futabas verden.
      Personlig var jeg mere førnøyd med JR enn Futaba men det er vel kanskje som med mobtlf at når man blir vant til et merke blir det meste annet komplisert og tungvindt ang meny å oppsett, hvertfall i begynnelsen syns jeg.
      Så jeg lurer på om du vet noe om ca pris den blir havne på her til lands??
      Fant den utenlands å der skulle dem ha 1449 dollar. Men med mva og ellers avgift er jeg spendt på hva den ender på her.
      ​​​Kim-Arne
        Er ikke sikker på hva den vil havne på og har bare sett spekuleringene på nettet. Elefun har ikke fått pris, men jeg poster så fort jeg vet noe!
          Virker som denne radioen lot vente på seg, begynner bli lett utålmodig av å vente.
          Spurte elefun om de vet noe mer når den kommer å det gjore de desverre ikke.
          Så da er det nok bare smøre seg med tålmodighet.
          ​​​Kim-Arne
            Litt utålmodig jeg også men klarer meg fint med 8'ern inntil den kommer
            mvh
            Alf
              Så et sted at den skulle komme rundt midten av februar. Skal se om jeg finner igjen hvor jeg leste det...
              Edit: Fant det her: https://rcjapan.net/index.php?main_p...ducts_id=11933
              Nå gjelder kanskje ikke denne datoen utenom Japan...
                Flott.. Da er det jo bare snakk om uker igjen. Kan virke som det blir brukbar pris å. Men det gjenstår å se. Håper dem har bra mottakere til den.
                ​​​Kim-Arne
                  JR XG11 - Ventes - elefun.no - Radiostyrt hobby
                  Radioen er lagt inn i webshop, og prisen er satt til 5.995,-
                  XG11 fra JR med 11ch DMSS mottaker ventes inn, forhåpentligvis leveres radioen i midten av Mars!
                  XG11 leveres med den nye DMSS-modulasjonen fra JR som gir sikker, rask og effektiv overføring av signaler fra radio og til mottaker. Systemet har også innebygget telemetri slik at man på en enkel måte kan få mulighet til å se mottakerbatterispenning, motortemperatur, turtall osv fra modellen rett i displayet på radioen.
                  Radioen har programmeringsmuligheter for akro/skala, helikopter og seilfly. Den er utstyrt med SD-kort og har stort lettlest display for god oversikt og enkel programmering. Videre leveres radioen med LiFe TX-batteri og lader til dette. På grunn av det lette LiFe-batteriet balanserer radioen veldig bra med nakkestropp så ingen bruk av nakkestropp-adapter er nødvendig.
                  Mer info kommer når radioen har landet!
                    Synd den ikke har mylighet til og kjøre DSM2. For meg som har JR DSX9 DSM2 og sitter med 14 mottakere til den blir det jo en kostbar afære om en vil skift til ny radio.
                      Virker som en meget spennende sak og prisen er ikke så verst den heller.
                      Så det er vel bare prøve finne ut om det er verdt å bytte ut bøtter å spann med mottakere.
                      Som bardp sier så kan det bli en kostbar afære hvis man skulle ta det skrittet å bytte.
                      Å jeg har inntrykk av at annen hands verdi på radioutstye er så lav at man klarer ikke berge store slompen heller med så selge det man har.
                      ​​​Kim-Arne
                      • #12
                        Høres veldig bra ut, da blir det ny radio til sommeren Håper den er så bra som feks 9x har vært Og håper den har lite barnesykdommer
                        • #13
                          Tror aldri jeg har hørt at JR har barnesykdommer?.
                          ​​​Kim-Arne
                          • #14
                            Ikke jeg heller. Har bare hatt feilfire Radioer selv så håper det fortsetter
                            • #15
                              Ondsinnede rykter skal ha det til at ny launchdate for XG11 er 7 mai.
                              Ser ut til å bli mye morro til JR etterhvert da.
                              Sist ut er JR DMSS Sensor TLS1-PWR Effektmåler - elefun.no - Radiostyrt hobby
                              Har vel i grunn alt som trengs etter hva jeg kan se...
