Har hatt dette i laaaaang tid nå, og enda ikke flydd det, så nå gidder jeg ikke mer. Heliet har ca. 5 turer av annen pilot.Kan til nød slakte det og selge løst, men helst ikke.Er IKKE interessert i å bytte mot heli, kan vurdere seilfly.Model Specifications:* Length:52.5" (1333mm)* Height: Flybarless - 17.25" (439mm)* Rotor Span: 1561-1601mm - 690-710mm blades* Tail Rotor Span: 286mm with 105mm T/R blades* Avg. Ready-to-Fly Weight:12-13lbs - 5.5-5.9kg (less fuel)* Main Drive Ratio:6.89:1 (7.29:1, 6.53:1 options)* Tail Drive Ratio:4.59:1* Main Rotor Blades:690-710mm* Recommended Power:23-29cc R/C Style Gas Engine1 x Whiplash 90 Gasser Flybarless Kit1 x GT-5 3-Axis Gyro1 x RCE-G600 Governor RCE-G6001 x DS615 Digital Servo (throttle)3 x Align BL700H High Voltage Cyclic Servo1 x Align BL750H High Voltage Rudder Servo1 x Zenoah bb17x - G270RC 3 HP Engine (4-Bolt Topend)1 x Radix 710mm Flybarless
More...
More...
