Oppdatering Inspire 1
  • Oppdatering Inspire 1
    Har en Inspire 1 som aldri har vært oppdatert.
    Har nå fått oppdatert sendere (drone+gimbal) og kamera, men selve
    drona vil altså ikke oppdateres. Usikker på hvordan det er med batteriene.
    Ligger på microsd i kamera, og oppdateringa starter aldri (hører ikke de høye tonene).
    Ideas anyone?
    Delete history success.
    Result: Abort.
    The current firmware does not support downgrade. Use a different version of firmware to downgrade the target version.
    ========== 2015.11.10 18:24:16 =====================
    Packet: WM610_FW_V01.03.00.00.bin
    Result: Abort.
    ========== 2015.11.19 21:46:20 =====================
    Result: Abort.
    ========== 2015.11.26 19:56:33 =====================
    Result: Abort.
    ========== 2015.11.28 15:56:26 =====================
    Result: Abort.
    ========== 2015.11.28 16:12:33 =====================
    Result: Abort.
    ========== 2015.12.11 14:25:46 =====================
    Result: Abort.
    ========== 2015.12.11 14:38:38 =====================
    Result: Abort.
    ========== 2015.12.12 14:26:00 =====================
    Result: Abort.
    ========== 2015.12.12 14:41:09 =====================
    Result: Abort.
    ========== 2015.12.16 17:55:46 =====================
    Result: Abort.
    ========== 2015.12.16 17:56:16 =====================
    Result: Abort.
    ========== 2016.01.16 18:09:33 =====================
    Result: Abort.
    ========== 2016.02.18 19:36:48 =====================
    Result: Abort.
    ========== 2014.01.01 00:00:04 remo-con disconnect======
    Packet: WM610_FW_V01.06.00.40.bin
    Upgrading ...
    Result: Success.
    ========== 2014.01.01 00:00:06 remo-con disconnect======
    Packet: WM610_FW_V01.11.01.50.bin
    Upgrading ...
    ========== 2018.05.18 20:23:21 =====================
    Upgrading ...
    ========== 2018.05.18 20:26:56 =====================
    Upgrading ...
    Upgrading ...
    Result: Failed.
    Reboot the aircraft and try to upgrade the firmware again.
    Result: Failed.
    ========== 2014.01.01 00:00:05 remo-con disconnect======
    Result: Failed.
    ========== 2018.05.18 21:46:08 =====================
    Result: Failed.
    ========== 2014.01.01 00:00:07 remo-con disconnect======
    Result: Failed.
    ========== 2018.05.18 21:51:55 =====================
    Result: Failed.
    Result: Failed.
    Result: Failed.
    Result: Failed.
    Result: Failed.
    Result: Failed.
    Result: Failed.
    Result: Failed.
    Result: Failed.
    ========== 2018.05.18 22:55:45 =====================
    Result: Failed.
    Result: Failed.
    ========== 2018.05.18 23:00:44 =====================
    Result: Failed.
    ========== 2018.05.18 23:27:52 =====================
    Result: Failed.
    ========== 2018.05.18 23:33:42 =====================
    Result: Failed.
    Result: Failed.
    Result: Failed.
    Ideas anyone?
    Er du sikker på at den har eldre fw? Isåfall ville jeg prøvd med en sw som er et par versjoner opp fra den som ligger på og jobba meg oppover på den måten.
    Sent fra min SM-G955F via Tapatalk
      Har ikke noe med denne meldingen å gjøre ? "The current firmware does not support downgrade. Use a different version of firmware to downgrade the target version."
      Bfight 210
      De Havilland DH 2 skala 1/5,3
      Phoenix RC Club
        Fikk det til etterhvert da .... Nå må jeg bare få USB'en til å funke på controller med 1.7.80 firmware :/
        Merker ikke at jeg kopler til telefon eller usb-stick .... pokkers ræl altså...
