SisT FW 190 kvartskala
  • SisT FW 190 kvartskala
    Tenkte å lage en A til Å montering her inne siden jeg synes Facebook er totalt ubrukelig til byggeblogger. Kjekt for seg selv men gir ingen eller minimal glede og utnytte for andre som har tenkt til å bygge tilsvarende....
    Modellen kom vel for 1,5 år siden men huset har vært fult av prosjekter. Sannsynligvis burde jeg ventet en stund til med å starte men nå var tålmodigheten slutt. SisT Models laget tidligere en fin skala FW 190 i 1:5, startet opp med 1:4 men formene ble solgt videre og en annen tysker som driver produksjon i meget liten skal men den ser veldig fin ut og er godkjent av mrFW himselv, Wulf på forumet.
    The SiSt FW-190 is the pinnacle in model aircraft kit design, this is a 100% scale rendition of the original.The SiSt team used original drawings and a very unique plug fabricating process to achieve these flawless results. Using their techniques they were able to model all the realistic surface features, butt joints and plate overlaps of the original aircraft. Plates looks like plates, fabric like fabric and rivets like rivets. Additionally, all inspection covers and hatches have been incorporated in the mold at the proper position.The model has over 7200 rivets, approx. 250 screws visible, rudder and elevators have a fabric covered appearance with scalloped tape as on original aircraft, true to scale hinges etc.; also the pivot points of the hinges agree with those of the original. Only minor aerodynamic changes were being made given the smaller scale of the airplane and a Naca 2415 airfoil was being used with a slight washout for that reason alone. This is a very complete kit which comes with a extensive pack of formers, parts and accessories. Hands down one of the most stellar kits on the market, off the beaten path.
    Scale 1 to 4
    Wingspan 103.1 inches
    Length 88.6 inches
    Weight ca. 44 lbs+
    Power Moki S250
ID:	638148Click image for larger version
ID:	638149Click image for larger version
ID:	638153Click image for larger version
ID:	638150Click image for larger version
ID:	638151Click image for larger version
ID:	638152Click image for larger version
Name:	RMK 01 - 04.jpg
    Fikk sortert ut litt deler og startet litt mer reserch. "Byggeveiledning" er noen skarve A4 sider med beskrivelse av forsterkning av vingeinnfestningene og that`s about it.... Derfor er det greit å sjekke litt fora og se hvordan ting blir gjort.
    Bestemte meg for å starte bak og gjøre ferdig byggingen av selve høyderorene. De bygges på tradisjonelt vis og linkes sammen med sekskantet glassfiberrør. Researchbilder stemmer ikke helt overens med min tegning men det er et viktig område og bygger selve rammen rundt sekskant glassfiberhylsen litt mer massiv. Veldig lett selvfølgelig. ønsker ikke å pådra meg for mye vekt bak selv om Mokin upfront veier endel.
Name:	2016-05-22 19.33.38.jpg
Name:	2016-05-22 19.33.50.jpg
Name:	2016-05-22 19.54.50.jpg
Name:	2016-05-22 21.05.32.jpg
      Mens jeg grubler på den beste løsningen så får man perforere litt fly....
Name:	2016-05-22 20.03.13.jpg
Name:	2016-05-22 20.03.20.jpg
Name:	2016-05-22 20.03.33.jpg
Name:	2016-05-22 20.03.36.jpg
Name:	2016-05-22 20.03.40.jpg
Name:	2016-05-22 20.21.27.jpg
Name:	2016-05-22 20.21.33.jpg
Name:	2016-05-22 20.21.37.jpg
Name:	2016-05-22 20.21.41.jpg
Name:	2016-05-22 20.55.34.jpg
Name:	2016-05-22 21.05.27.jpg
Name:	2016-05-22 21.05.29.jpg
        Denne blir artig å følge med på.
          Hadde vært moro å flydd den ulakka i løpet av høsten men gjenstår jo litt jobb. Får jobbe litt jamt og trutt så får vi se.
          Tilpasser litt luker innimellom, de er ikke ferdig slipt hvis dere lurer på ujevnhetene...
Name:	2016-05-23 12.24.52.jpg
Name:	2016-05-23 12.24.55.jpg
Name:	2016-05-23 12.25.02.jpg
Name:	2016-05-23 12.25.05.jpg
            Dette ser ut til å bli veldig lekkert!
            Jees! har du laget alle de naglene på vingene selv? rimelig høy tetthet, ser ut som om det har tatt sin tid
              Ikke laget nagler, bare betalt for de.... 😁
                Dette blir en flott modell Alf!
                  Knallbra at du lager bygginga her Alf og ikke på Facer´n. Ser ut til å være et veldig fint sett og jammen er det masse nagler gjort i den. Blir morro å følge med på den. Husk at den flyr like fint med eller uten lakk ) Knallbra !
                  Totto Dahle
                  Medlem Agder Modellflyklubb
                    Bestemt deg for fargeskjema på dette smykket ?
                      Nope, men tar gjerne imot forslag her. Kan godt tenke meg et norskbasert fly men vet ikke helt. Ellers så er Heinz Baehr sin utrolig fin
                      • #12
                        • #13
                          Da datt jeg ned på Nr 13
                          Totto Dahle
                          • #14
                            Problemet er at den ikke har operert i nårje
                            • #15
                              Denne kan du jo "besøke" også.
