Etter at containeren ankom Elefun i går ble det i dag klart at de ønsket å sende en Katana 120 til test. Denne skal få sterke HD servoer rund baut, nye Hyperion LiFE batterier og RCGF 26 kubikk bensinmotor med pittspotte slik at den monteres opp/ned.
Sist jeg bygde og testet Phoenix model var det en semiskala Spitfire som jeg er meget fornøyd med. (MFN) ModellflyNytt.no God kvalitet og fine flyegenskaper. Gleder meg til denne!!
Esken er allerede sent og bilder og tekst vil komme i ny tråd fortløpende...
Fly:
Siden finnes ikke
# This KATANA 120 size radio control plane is capable of performing extreme 3D aerobatics: Blenders, Elevators, Harriers, Torque Rolls, Flat Spins, etc. And just wait till you perform an elevator transitioning into a harrier then into a torque roll... The stability of this design virtually eliminates wing rock making high alpha maneuvers a breeze. And lets face it, being able to perform beautiful manuevers like this is a most satisfying experience when flying rc plane. The KATANA also has smart design features such as a two-piece wing and this makes more convenient to transport, With our KATANA, you get all of these plus more!
# Covered in genuine ORACOVER
# Can be flight ready in just 2 to 4 hours
# Bolt-on two-piece wing for easy transport and setup at the field
# Superior precision and 3D performance
# Flies with a wide variety of engines
# Designed by world-class pilot
# Fiberglass cowl and wheel pants and aluminum landing gear
# Lightweight balsa-and-ply construction
# 95% factory built, covered and painted
# Can be converted for electric flight
# Longer landing gear increases prop clearance
# Wingspan: 1720mm (67.7in)
# Length: 1540mm (60.6in)
# Weight: 4500g~5000g
# Engine: 120 two stroke
# Radio: 4 channel ? 5 high torque servo & 1 standard servo
Motor og pitts-potte:
Siden finnes ikke
Siden finnes ikke
Servoer og batterier:
Siden finnes ikke
Siden finnes ikke
Fly:
Siden finnes ikke
Siden finnes ikke
Siden finnes ikke
Siden finnes ikke
Siden finnes ikke
