www.smallsize.no sender ennå en modell til test. En EDF jet med vsp på 92 cm og 4S LiPO oppsett. Modellen er BNF og skal være flyklar på meget kort tid. Etter å ha googlet litt og sett diverse videoer kan jeg bare kjenne at jeg gleder meg til litt fart og moro......
ParkZone Habu Jet fra Smallsize!
Tags: None
Spesifikasjoner etc
Specifications
* Wingspan: 36.3 in (920 mm)
* Overall Length: 43.3 in (1100 mm)
* Flying Weight: 2.8 lb (1300 g)
* Motor Size: E-flite BL15 DF 3200Kv six-pole brushless inrunner (installed)
* Radio: AR500 2.4GHz 5-channel Sport DSM2 (installed)
* Servos: 5 total, 3 digital metal-geared (nose steering, rudder, elevator), 2 standard (aileron)
* Trim Scheme Colors: Silver foam with electric blue and yellow
* CG (center of gravity): Approximately 4 inches from leading edge of wing at root
* Speed Control : E-flite 60A Switch-Mode BEC brushless (installed)
* Recommended Battery: E-flite 4S 3200mAh 30C Li-Po (included)
* Aileron: proportional
* Elevator: proportional
* Rudder: proportional
* Throttle: proportional
* Charger: 3-4 cell DC powered variable rate balancing LiPo charger (included)
* Landing Gear: Optional landing gear is included____________________________
* E-flite BL15 3200Kv brushless ducted fan motor with E-flite Delta-V™ 15 ducted fan unit (installed)
* E-flite 60A Pro with Switch-Mode BEC ESC (installed)
* AR500 DSM2 5-channel sport receiver (installed)
* 4S 14.8V 3200mAh 30C Li-Po battery (included)
* Variable rate 3- to 4-cell DC Li-Po balancing (included)
* Full 4-channel control, includes fully functional rudder
* Wing and airframe design optimized for a wide flight envelope
* Silver Z-Foam™ construction
* Removable landing gear
The ParkZone® Habu EDF Jet is a full-throttle thriller capable of blistering speeds and precise aerobatics. At the heart of this spine-tingling performance is the phenomenal power of E-flite’s BL15 3200Kv brushless ducted fan motor mated to an E-flite Delta-V™ 15 ducted fan. The potent combo produces enough thrust for outstanding climb performance and thrilling high-speed passes. When it comes time to throttle back and enter the pattern, the Habu’s remarkably wide flight envelope and forgiving slow-speed handling will reward anyone used to flying faster sport planes with picture-perfect, nose-high touch downs and takeoffs.
Getting this Bind-N-Fly™ version airborne is about as simple as it gets. Just attach the wing and tail, charge the battery, bind the receiver to your full range DSM2™ transmitter and you’re flying.
This is anything but the same old sport flying experience. If you’re an intermediate to experienced pilot looking for high-speed jet thrills, the ParkZone Habu EDF Jet is just what you’re looking for . . . and a whole lot more.____________________________
Vet du når denne er i salg her til lands og ca pris?Align T-Rex 700
Align T-Rex 250
Hangar 9 Sundowner
Hangar 9 Spitfire mkII,Saito FA100
Dynam Extra 330
Vmar Easy 3d,TT pro 46
ARC Cessna Cardinal
Hacker Arrow 3d (ikke ferdigbygd)
CMPro Giles 202 140size,Roto 35vi
GreatPlanes P40 Warhawk (os25LA)
ǝʌısuǝdxǝ sı dn puɐ dn sı uʍop ''''pǝʇɹǝʌuı puɐ ʍo1 buıʎ1ɟ uǝɥʍ
Den har akkurat kommet inn døra hos www.smallsize.no
Vet at det var mange som var forhåndsbestilt og at vi i MFN var heldige som fikk en til test, men jeg ville prøvd en mail eller tlf til de?____________________________
Montering og flyging her:
Habu Jet fra Smallsize - (MFN) ModellflyNytt.no____________________________
