Test av Ultra Micro Mosquito Mk VI BNF fra Smallsize
  • Test av Ultra Micro Mosquito Mk VI BNF fra Smallsize
    Smallsize har ønsket å prøve ut en ny modell og Modellflynytt redaksjonen får straks en slik i hende og det vil bli foto og videoshoot samt litt beskrivelser av egenskaper etc.
    Link til modellen her: Small Size Hobbyland AS
    Her er foreløpig informasjon klippet fra Parkzone:
    • Wingspan: 20.5 in (520mm)
    • Overall Length: 15.2 in (387mm)
    • Flying Weight: 2.60 oz (74g)
    • Motor Size: 8.5mm coreless brushed
    • Radio: 4 channel transmitter minimum
    • Servos: AS2000L linear long throw servo x2
    • CG (center of gravity): 38mm from leading edge of wing at fuselage
    • Prop Size: 110 x 80mm 3-blade
    • Recommended Battery: 250mAh 20C Li-Po
    • Minimum Age Recommendation: 14 years
    • Experience Level: Intermediate
    • Recommended Environment: Indoor/Outdoor
    • Assembly Time: Less than 1 Hour
    • Is Assembly Required: No
ID:	629234Click image for larger version
ID:	629245Click image for larger version
ID:	629244Click image for larger version
ID:	629243Click image for larger version
ID:	629242Click image for larger version
ID:	629241Click image for larger version
ID:	629240Click image for larger version
ID:	629239Click image for larger version
ID:	629238Click image for larger version
ID:	629237Click image for larger version
ID:	629236Click image for larger version
ID:	629235Click image for larger version
Name:	Skjermbilde 2011-06-08 kl. 12.41.27.png
ID:	629229Click image for larger version
Name:	Skjermbilde 2011-06-08 kl. 12.40.51.jpg
ID:	629230Click image for larger version
Name:	Skjermbilde 2011-06-08 kl. 12.41.08.png
ID:	629231Click image for larger version
ID:	629232[/ATTACHClick image for larger version
      You will need:
      A 4+ channel DSM2 compatible transmitter is all you will need.
      • Spektrum AR6400T 6-Channel DSM2 Receiver/Dual ESC/Servos Unit installed
      • Twin engine Mk VI with counter-rotating 3-blade propellers
      • Independent Spektrum AS2000L ultra micro aileron servos
      • Clear canopy and authentic mossy camouflage scheme
      • Full 4-channel control
      • Steerable tail wheel and removable landing gear
      • Capable of aerobatics like rolls, loops, and more
      Constructed almost entirely of plywood and powered by twin Merlin V12s, the DeHavilland Mosquito Mk VI was incredibly fast and maneuverable for a plane of its size. This speed and maneuverability combined with its relatively long range earned it a variety of combat roles during World War II that included everything from low-level reconnaissance to anti-shipping and night fighter missions.
      The first-ever 4-channel twin-engine ultra micro, the ParkZone Ultra Micro Series Mosquito MK VI brings this famous British WWII fighter to life in your own backyard. Scale details include the twin motors, authentic mossy camouflage paint scheme, molded clear plastic canopy, landing gear with steerable tail wheel, and even dummy cannons. The 4-channel control with elevator, throttle, rudder, and aileron provide full control for precise flying and maneuverability. This Bind-N-Fly comes out of the box pre-assembled and ready to take flight in the time it takes to charge your 250mAh battery and bind it to your favorite DSM2 transmitter.
    ParkZone RC Products | Horizon Hobby
    Ett par videoer fra Parkpilotene:
      Egen bildekollasj
ID:	579771Click image for larger version
ID:	579769Click image for larger version
ID:	579770Click image for larger version
ID:	579779Click image for larger version
ID:	579778Click image for larger version
ID:	579777Click image for larger version
ID:	579776Click image for larger version
ID:	579775Click image for larger version
ID:	579774Click image for larger version
ID:	579773Click image for larger version
ID:	579772Click image for larger version
        Video og oppakking av Mosquito Mk VI
          Var heldig i sommer og fikk flydd en kveld det ikke blåste eller regnet...
