Test: ST Model FW 190 fra Elefun
  • Test: ST Model FW 190 fra Elefun
    Ny og oppdatert warbird fra ST Model. Teksten er fra Elefun: STM FW190 Warbird RTF 2.4GHz - elefun.no - Radiostyrt hobby
    Tøff Warbird fra STM med retract, modellen har ett vingespenn på 113cm og leveres med elektronikken ferdig montert. Kun enkel montering av høyderor, propell og lignende kreves for å kunne fly. Flyet leveres med 3S 1800mah LiPo med Deans og 12V lader, 2.4GHz radioutstyr er også med for å gi god rekkevidde og forstyrrelsesfri flyving.
    Modellen flyr veldig bra og med retract får man en ekstra dimensjon i flyvingen. Det eneste som trengs i tillegg her er 8AA batterier til radioen. Merk at laderen går på 12V, så om man ønsker ett 220V adapter kan man kjøpe det i tillegg ( E-000512 ).
    The Fw-190A was a serious shock to the RAF when it came on the scene in 1942. Until the Spitfire MkIX arrived it completely outclassed the Spitfire MkV. No wonder it was nicknamed the ´Butcher Bird´! The Fw-190 swiftly became the mount of choice for many German fighter aces and remained in production in various guises for the rest of the war. ST have re-created a fabulous scale version of the Fw-190A and lavished the level of detail on it that has not been seen on a foam model before.
    There is a fully scale retracting undercarriage as standard with contoured doors that has working, sprung oleo struts. The split flaps have concealed linkages inside the wings and are amazingly effective. Slow, controlled landings on calm days are no problem at all. The control surface hinges are fully hidden and the horns/pushrods have been minimsed so as not to spoil the scale appearance.
    The powerfull brushless, outrunner motor drives a scale, 3-bladed propeller through a scale spinner with integral fan. Just like the real one!!! The fan also provides the necessary cooling air flow to the motor, battery and ESC and that air exits via the scale exhaust recesses. Power control comes from the latest 36A ESC with integral BEC circuit. That BEC is more than enough for the five pre-installed, 9g servos.
    The cockpit has a seat, control column and instrument panel and just needs a pilot to complete.
    The stunning colour scheme and decals are the icing on the cake, giving this Fw-190 the ´wow´ factor that she richly deserves.
    Out on the field you quickly discover that the performance matches the looks. The controls are smooth, powerful and give the right level of feedback. The motor will power her through all the scale manoeuvres and many more. Big, wide loops and slow rolls are the order of the day!
    Drop the flaps for landing and she settles into a controllled approach in just the right atttitude.
    The Fw-190 from ST Model makes an ideal first warbird to fly (if you can stop yourself admiring it on the ground!)
ID:	582545Click image for larger version
ID:	582558Click image for larger version
ID:	582557Click image for larger version
ID:	582556Click image for larger version
ID:	582555Click image for larger version
ID:	582554Click image for larger version
ID:	582553Click image for larger version
ID:	582552Click image for larger version
ID:	582551Click image for larger version
ID:	582550Click image for larger version
ID:	582549Click image for larger version
ID:	582548Click image for larger version
ID:	582547Click image for larger version
ID:	582546Click image for larger version
Name:	Skjermbilde 2011-10-05 kl. 17.01.24.jpg
      Synes modellen ser bra ut og mest spent på det opptrekkbare. Stallhastigheten ser ut til å være gangfart!
        Willkommen til "The Dark Side" Alf. Blir moro å titte på den enda det er ett batterifly
        Understellet ser skikkelig skala ut!
          Blir knall. Du ble glad nå da du slipper å stille alene som tyske Luftwaffe?....
          mvh
          Alf
            5 kanaler
            Den ser knall ut
            blir den levert med 5 kanalers sender på 2,4? i så fall hadde det vært greit om du tester den med Y-kabel på flap og understell som det sies på en youtubefilm.
            (har ikke 2,4 sender selv)
            Og denne fikk jeg veldig lyst på! utstyret kan passe i en P47 fra house of balsa når FW ikke er mere? Følger med på RCmarked NÅ
            (selv om jeg helst vil bygge en i Balsa)
            Mvh Andreas
              Kommer tilbake med detaljerte opplysninger så fort den er i hus. Det er ikke helt enkelt å finne ut av hva ST model leverer sånn fra hjemmesiden deres.
              Men kommer i eskeåpningen som vil bli filmet
                Eskeåpning
                Da var esken i hus, flyet montert og testflydd i løpet av ettermiddagen.
                Og modellen ser meget bra ut, skalamessig meget bra til å være foamie. Jeg har hatt forumets mr. Wulfmeister innom for å se på den. Han er noe mer enn middels interessert i tyske fly fra 1940 til 1945, noe snevert område mener noen mens andre lever for det
                Selve monteringen og justeringen tar 10 minutter. Staben stikkes inn i kroppen og skrus fast med en skrue. Linken settes på og låses med plastikk klips.
                Jeg valgte å binde opp mottakeren uten propell og vinge. Inn med bindkontakten, på med 3S LiPO batteriet på esc og slå på senderen med bindbryteren holdt inne ett par sekunder før jeg slapp. Grønt lys i mottakeren, av med strøm, ut med plugg og på med strøm igjen så var modellen bundet opp.
                Gear og flap er koblet til samme kanal siden senderen kun har en bryter. Hjul ute så er flapsen nede, dog er utslagene små og i praksis fungerte det upåklagelig. Balanseror og gear/flap kabel inn i mottakeren og vingen skrus fast med en plastskrue.
                Viften settes på først, deretter propellakselen og propell som skrus fast før spinneren skrus til.
                Utslagene på modellen så bra ut og hjul og flap gikk pent og lukket og låste på riktig steder. Meget bra!!
                Laster opp video av eskeåpning nå, mens jeg i mellomtiden legger ved litt bilder av modellen og utstyret.
                LiPO laderen lader med 1.1A på 3S og bruker derfor bortimot 2 timer fra tomt batteri. Den er kun koblingsbar mot 12V kilde.
ID:	582628Click image for larger version
ID:	582630Click image for larger version
ID:	582629Click image for larger version
ID:	582631Click image for larger version
ID:	582632Click image for larger version
ID:	582633Click image for larger version
ID:	582639Click image for larger version
ID:	582643Click image for larger version
ID:	582642Click image for larger version
ID:	582641Click image for larger version
ID:	582649Click image for larger version
ID:	582636Click image for larger version
ID:	582644Click image for larger version
ID:	582645Click image for larger version
ID:	582640Click image for larger version
ID:	582634Click image for larger version
ID:	582635Click image for larger version
ID:	582637Click image for larger version
ID:	582638Click image for larger version
ID:	582648Click image for larger version
ID:	582647Click image for larger version
ID:	582650Click image for larger version
ID:	582654Click image for larger version
ID:	582653Click image for larger version
ID:	582652Click image for larger version
                    Jomfrutur
                      Ser ut som den flyr veldig bra, tross litt vind Fløy du med din egen radio? Så ut som at flaps var oppe da du taxet inn på slutten... Eller er det veldig små utslag...?
                        Den ble flydd med original sender og utslagene er bare små.
                        Til størrelsen å være så var den veldig stabil og fin, godt kontrollerbar hele veien.
                        Skal forske litt etterhvert med egen sender og mere utslag på flaps. Dog er det litt sært da man overhodet ikke trenger det, men liker å utforske...
                        mvh
                        Alf
                          Har flydd min 2 batterier til i dag og kan bare si meg enig.
                          Modellen flyr godt og den ser bra ut. Blir mere video senere. Skal legge ut litt inflight bilder også
                            Litt bilder
ID:	582797Click image for larger version
ID:	582799Click image for larger version
ID:	582793Click image for larger version
ID:	582794Click image for larger version
ID:	582795Click image for larger version
ID:	582796Click image for larger version
                              Litt mer flyging fra sist uke:
