Ryktene har versert en stund men nye JR XG11 nærmer seg faretruende og min er allerede bestilt etter å ha blitt veldig glad i XG8 radioen.
Kommer tilsvarende artikkel på denne som XG8 med pros and cons.
Her er noen foreløpige fakta tatt fra JR sin Facebookside:
[System List]
●COMMON
●HELI
●ACRO
●GLID
- DMSS Telemetry function
- Analog trim version has a new line-up
- XG11 transmitter has become a common for Heli and Acro.
- Batteries for TX is LiFe(2F 1400 6.4V 1400mAh) and TX is included in charging circuit.
DC jack is same as XG8. - My List
- Easy setting function(Wizard)
- Touch select function (You can select the display icon by hopping switch, too.)
- Advanced digital trim
- Trainer jack
- SD card slot
- Graphic display with backlight function
- Stick sping adjust
- Throttle stick angle adjuster(Digital version : Enclosed. Analog version : Installed)
- Short stick head for better operation (Red color anodized stick) Option short stick head can be used.
[System List]
- MODEL SELECT
- MODEL COPY/ERASE
- TYPE SELECT
- MODEL NAME
- FLIGHT MODE NAME
- TRIM SYSTEM
*[HELI]
[NORM] is added into Throttle trim in Digital trim version, same as XG8
*[GLID] [FRPN] Direction of Flapperon trim is added, same as XG8 - STICK POSITION SW * Upgrade is under study
- TRIM INPUT SW * 4 genealogy, same as XG8
- STICK ALERT * , same as XG8
- WARNING
- DEVICE SELECT
* Trim(momentry, 2pcs & 3 position function) are added in Input divice.
[HELI] SWASH TYPE
[ACRO] [GLID] WING TYPE - TX SETTINGS
* ①Idle alert is added, same as XG8
* ②ON/OFF new function for Model link - TRAINER * SW Select is added(Trainer SW/LTRIM/RTRIM)
- THRO STICK DIRECTION * New function from 11X Zero/DSX11
- ALL SERVO HOLD
- STICK MODE * New function from 11X Zero/DSX11
- BIND & RANGE * , same as XG8
- TELEMETRY * , same as XG8
- FAIL SAFE
●COMMON
- D/R & EXP
* POS is extended to 8 genealogy.
POS can be changed at stick postion switch.
(6pcs. of SW SEL is added)
DELAY can be set up at 8 type at POS change. - TRAVEL ADJUST
- LIMIT ADJUST
- SUB TRIM
- REVERSE SW
- SERVO SPEED
- PROGRAM MIX1-6
* ①P.MIX1-3 is not only normal fix but also curve, same as XG8
* ②Curve can be set up at 5 points in the middle.
(For DSX11, the curve has just 5 points but XG11 has 7 points, instead.Also, in the middle, the point is only 3 for DSX11 but XG11 has 5 points). - TIMER
- MIX MONITOR
- SERVO MONITOR
●HELI
- THROTTLE CURVE * Curve can be set up at 5points in the middle.
- PITCH CURVE * Curve can be set up at 5points in the middle.
- TAIL CURVE * Curve can be set up at 5points in the middle.
- THROTTLE HOLD
- GYRO SENS
* ①New set up function for TAGS01.(In the Gyro icon, DSX11 has only 2 selction, but XG11 has 3selection.
In the new selection, you can see Triple Axisdisplay icon and you can set up TAG01 adjustment in this icon.)
* ②Trim input can be made, same as XG8 - GOVERNOR * Trim input can be made, same as XG8
- SWASH MIX
* ①PIT->AILE->ELEV MIX correction new function, same as XG8
* ②E-Ring gain new fuction, same as XG8
* ③AILE->ELEV, ELEV->AILE trim input new function are added. - THROTTLE TRIM
- MIX to THROTTLE
- FLIGHT MODE DELAY
●ACRO
- THROTTLE CURVE *Curve can be set up at 5points in the middle.
- PITCH CURVE *Curve can be set up at 5points in the middle.
- THROTTLE HOLD
- GYRO SENS
- THROTTLE TRIM
* [ACRO] IDLE ADJ. to be extended to 2 genealogy is studied(New). - FLAP SYSTEM * Trim input fuction is reinforced.(same as XG8
- SNAP ROLL
* SNAP ROLL ON/OFF can be selected by not only Snap roll switch but also trim lever.
Stick ON/OF remains unchanged. - DIFFERENTIAL * Trim input function(same as XG8
- AILE -> RUDD MIX
- AILE -> FLAP MIX
- ELEV -> FLAP MIX
- RUDD -> AILE/ELEV MIX
* ①Trim input fuction(same as XG8
* ②Curve MIX function-up is studied. - BALANCE * New function
●GLID
- DIFFERENTIAL
- AILE -> RUDD MIX
- BALANCE
(This is also new function, like DSX12. Although DSX12 is just fixed point, XG11 has multi-point.) - FLAP RATE
- MOTO SYSTEM
- CAMB SYSTEM
- BRAKE SYSTEM
* Trim input function is reinforced - FLAPRON MIX
- ELEV -> CAMB MIX
- RUDD -> SP01 MIX
