Hallå hobbykamerater
Det kommer en Aeroworks edge 35% til test fra RCPRO AEROWORKS EDGE 540 100CC ORANGE - ARF-QB QUICK BUILD | RCPro.no
Dette er et skikkelig kvalitetsprodukt som er en fryd å sette sammen. Jeg vet, for jeg har hatt flere (og har en i stua).
I følge Jason Noll er dette et 3d-monster som også flyr imac meget bra. Eller bare høl i lufta.......meget bra
Du kan få denne i gul eller orange. Denne fra RCPRO er orange.
Litt info:
Aeroworks is proud to add the New 100cc Edge 540 to their line
of QUICK BUILD Series Aircraft Designed with the customer in mind to provide the highest quality, light
weight construction and fastest build time possible.
With the up coming popularity of Air Racing the new Edge 540 fits the bill.
Scale lines, light strong construction and race ready color scheme.
Aeroworks has Raised the Bar
The QB Series is top quality in both design and performance that will
set a new standard for ARF aircraft
With the Edge 540’s unbeatable stability and precision flight characteristics
it is certain to please both the beginner as well as the advanced competitor
Designed for both precision and 3D style flying this plane is sure to
out perform all other aircraft.
The Edge 540 was designed from the ground up to be a top performing aircraft.
Generous control surfaces and an awesome power to weight ratio make this
a plane you'll want to fly every visit to the field!
SPECIFICATIONS
Wing span 106 inches.
Wing Area 1958
Fuse Length 96" (Spinner to Rudder)
Fuse Length 93" (Cowl to Rudder)
Cowl Width 12.5”
Spinner Size 4”
Weight 27 to 28 lbs
Engine 100 cc
Radio 6 Channels minimum
FEATURING
Strong Light Weight Construction
Complete and Detailed Instruction Manual on CD
Painted and Pre mounted 7075 Aluminum Landing gear
Complete High Quality SAE Hardware Package Included
Adjustable pushrods with centering nut
Machined aluminum engine stand offs included
Carbon Wing Tube
Carbon Stab Tube
Professionally covered in ULTRACOTE
Pre-Hinged from factory (Ready to Fly) No gluing
Two Servo Wing
Large control surfaces double beveled for maximum throw
Pre Mounted Fiberglass Cowl and Wheel Pants
Flush fit cowl with No visible mounting bolts
Molded in Cowl Baffling
Pre Mounted and Tinted Canopy / Hatch assembly
Canister READY!
Pre installed and fuel proofed engine box
Laser cut engine mounting templates provided
Custom Throw Meter Included
Extra Ultracote covering provided for small repairs
Two Fuel tanks One for Smoke
8 to 10 Hours assembly Time
Servor som skal inn er en blanding av hitec 7955tg og 7950. Noen har jeg og resten kommer også fra RCPRO.
Regner med at det blir brytere fra XXL RC
Vi må nesten ha med en bra video av Jason Noll:
Jeg kommer med glede til å la andre prøve denne så det blir et skikkelig review, håper også folk vil teste den
Så var det motor da..........................HE HE.......
Litt info:
SPECIFICATIONS
Wing Area 1958
Cowl Width 12.5”
Spinner Size 4”
Weight 27 to 28 lbs
Engine 100 cc
FEATURING
Carbon Wing Tube
Carbon Stab Tube
Two Servo Wing
Canister READY!
