Eflite Carbon-Z Scimitar PNP fra Smallsize
  • Eflite Carbon-Z Scimitar PNP fra Smallsize
    Small Size Hobbyland AS
    Fikk en hyggelig mail fra Frode hos Smallsize i dag med bekreftelse på at denne kommer til test i løpet av kort tid.
    E-flite sitt første fly med thrust vectoring. Det vil si at når du svinger på rorene så svinger motoren også! Dette gjør flyet ekstremt villig til å svinge. Leveres som PNP versjon. Du trenger sender, mottaker, batteri og lader i tillegg.
    Specs
    Plane Type: Sport Planes
    Experience Level: Intermediate
    Power Plant Size: 25-46 Electric
    Recommended Environment: Outdoor
    Fuel Type: Electric
    Wingspan: 42.6 in (1080mm)
    Overall Length: 35.0 in (889mm)
    Wing Area: 565 sq. in. (36.5 sq. dm.)
    Flying Weight: 4.40 lb (2.0 kg)
    Motor Size: 32-size 1010Kv Brushless Outrunner (installed)
    Radio: AR600 6-channel DSMX receiver (installed)
    Servos: 5 digital high-speed, high-power sub-micro servos; 1 digital high-power metal-gear mini servo (installed)
    Trim Scheme Colors: Red, black, and white
    CG (Center of Gravity): 21.8-22.2 in (553-565mm) back from the airplane nose
    Wing Loading: 17.9 oz/sq. ft.
    Prop Size: 10 x 8
    Speed Control: 60-Amp Pro SB Brushless with Switch-Mode BEC (installed)
    Recommended Battery: 4S 14.8V 30C 3200mAh LiPo (included)
    Retracts: Optional
    Approx. Flying Duration: 5 minutes
    Is Assembly Required: Yes
    Charger: 3-4S DC Li-Po Balancing Charger (included)
    Control Throw (Ailerons): Low: 34mm up, 17mm down, 35% expo; High: 38mm up, 21mm down, 45% expo
    Control Throw (Elevator): Low: 25mm up, 17mm down, 20% expo; High: 44mm up, 36mm down, 55% expo
    Control Throw (Rudder): Low: 50mm right/left, 10% expo; High: 80mm right/left, 30% expo
    Spec_Assembly Time: 5-7 Hours
    Spec_Experience Level: Intermediate
    Spec_Fuel Type: Electric
    Spec_Plane Type: Aerobatic & 3D
    Spec_Power Plant Size: 25-46 Electric
    Spec_Recommended Environment: Outdoor
    Key Features
    • Dual rudder and vectored-thrust control on the yaw axis
    • Exceptionally strong and lightweight Carbon-Z structure
    • Digital high-speed servos installed
    • Single screw access to the electronic equipment
    • Effective front and side cooling inlets with interior venting
    • High-quality socket-head hardware throughout
    • Distinctive color scheme for superior visibility
    • Ready to accept optional E-flite electric retracts (EFLG110)
    • All components, including the nose and control surfaces, are easily replaceable
    Needed To Complete
    A 6+ channel DSM2- or DSMX-compatible transmitter capable of elevon mixing, dual rates, and exponential programming.
    The E-flite Carbon-Z Scimitar is true satisfaction for the RC pilot who desires flight performance and adrenaline pounding excitement previously thought impossible from a conventional aircraft platform. The fantasy-scale Carbon-Z Scimitar, designed by world aerobatic champion Quique Somenzini, bursts open the performance envelope with an evolutionary tailless swept wing. At the heart of the advanced Carbon-Z Scimitar is a specially tuned Q-Power system harnessed inside a revolutionary single-axis, vectored-thrust propeller system. In combination with the precision of carbon rod hinged elevons and twin rudders, a refreshing level of maneuverability can be explored after less than an evening’s worth of assembly time.
    Litt fabrikkbilder
ID:	587535Click image for larger version
ID:	587545Click image for larger version
ID:	587544Click image for larger version
ID:	587543Click image for larger version
ID:	587542Click image for larger version
ID:	587541Click image for larger version
ID:	587540Click image for larger version
ID:	587539Click image for larger version
ID:	587538Click image for larger version
ID:	587537Click image for larger version
ID:	587536Click image for larger version
      Og ett par videoer
        Litt vårlek med Scimitar fra Small Size Hobbyland AS
          Har sikla på detta en stund. Ser farlig moro ut!
          Får tukte Skyfun' som er rett rundt hjørnet, litt først før jeg koster på meg en sånn doning.
          Noen som har testa SAB sin Deltawing?
          Martin Holm - '85
          | DX7s |
          | Blade mCPX v2 | Parkzone UM P-51d | HK SkyFun 1.6kW |
            Legger til en liten bildekollasj etter flygning på Skoger
ID:	588646 Click image for larger version
ID:	588647 Click image for larger version
ID:	588649 Click image for larger version
ID:	588651 Click image for larger version
