Parkzone VisionAire AS3X BNF testes for Smallsize!
  • Parkzone VisionAire AS3X BNF testes for Smallsize!
    En ny Parkzone modell kommer om få dager fra Small Size Hobbyland AS
    Det er den nye acrotrainer modellen VisionAire med innebygd gyro som flys med 3S oppsett i passende hel inn i bilen størrelse. Modellen kommer her: http://shop.smallsize.no/product_inf...60a131506a3a54
    info fra produsent her:
    The ParkZone® VisionAire™ park flyer is specifically designed for sport pilots by 3D pioneer Quique Somenzini. Its wings are constructed of hollow Z-Foam™ material that has been reinforced with carbon fiber to create structures that are stiffer and lighter than solid foam. This rigid, lightweight airframe is paired with a powerful 10-size, 1250Kv brushless motor that delivers the vertical performance you need for an exhilarating 3D flying experience.
    What makes the VisionAire model such a great 3D plane for sport pilots is the advanced AS3X® (Artificial Stabilization – 3-aXis) System built into its AR635 receiver. The AS3X System works behind the scenes to counter the effects of wind and turbulence, using 3-axis sensing and flight control software tuned by Quique Somenzini. If you’ve never flown 3D before, this enhanced stability will give you the confidence you need to try high alpha maneuvers like harriers, hovers, torque rolls and more.
    You can adjust the amount of stability the AS3X System provides or turn it off completely, but even 3D pros will find flying with it on feels completely natural. There are no delays in control response or limits on the control throws. You’ll simply feel like you’re flying an expertly-tuned model that goes right where you point it.
    FeaturesShow More
    • Spektrum™ AR635 DSMX® receiver with AS3X® System, installed
    • Powerful 10-size BL outrunner, 1250Kv, installed
    • E-flite® 40A Lite Pro Switch-Mode BEC brushless ESC (V2), installed
    • E-flite 13-gram digital micro servos, installed
    • Clear belly window for monitoring AS3X System status
    • Carbon-reinforced Z-Foam™ construction
    • Leading-edge vortex generators
    • Double-beveled hinges for large control surface throws
    • Durable wire landing gear and large wheels for flying off grass
    • Two-piece wing for easy transportation and repair
    • Sharp Mirco Pecorari signature trim scheme
    • Includes 3S 2200mAh 25C Li-Po battery
    • Includes 2- to 3-cell DC variable rate charger
    • Requires a full-range 4+ channel DSM2®/DSMX aircraft transmitter, sold separately
    Spesifikasjoner
    Wingspan: 45.0 in (1143mm)
    Overall Length: 42.5 in (1088mm)
    Wing Area: 539 sq in (34.8 sq dm)
    Flying Weight: 43.7 oz (1240 g)
    Motor Size: 10-size BL10 brushless outrunner, 1250Kv (installed)
    Radio: AR635 6-channel DSMX® AS3X® sport receiver (installed)
    Servos: (4) 13 g digital high-speed servos (installed)
    Trim Scheme Colors: Blue, red
    CG (center of gravity): 4.5 in (115mm) back from the leading edge of wing at wing root
    Wing Loading: 11.7 oz/sq. ft. (35 g/sq. dm.)
    Prop Size: 12 x 4
    Spinner Size: 1.57 in (40mm)
    Speed Control : 40-amp Lite Pro Switch-Mode BEC brushless (installed)
    Recommended Battery: 11.1V 3S 2200mAh 25C Li-Po (included)
    Control Throw (Ailerons): Low: 70% up/down, 15% expo; High: 100% up/down, 25% expo
    Control Throw (Elevator): Low: 70% up/down, 15% expo; High: 100% up/down, 20% expo
    Control Throw (Rudder): Low: 70% right/left, 10% expo; High: 100% right/left, 15% expo
    Approx. Flying Duration: 6 minutes
    Charger: 2-3 cell DC Li-Po balancing charger
    Minimum Age Recommendation: 14 years
    Experience Level: Intermediate
    Recommended Environment: Outdoor
    Assembly Time: Less than 1 Hour
    Is Assembly Required: Yes
    Parts & Accessories
      Bildekolleksjon
ID:	597003 Click image for larger version
ID:	597016 Click image for larger version
ID:	597014 Click image for larger version
ID:	597012 Click image for larger version
ID:	597010 Click image for larger version
ID:	597008 Click image for larger version
ID:	597006 Click image for larger version
ID:	597004 Click image for larger version
          Quique Somenzini flyr den indoor
            Syns piloten i den siste videoen ligner veldig på Devin McGrath og ikke Quique Somenzini. Han som snakker i den første videoen er Somenzini.
            Anders Eiebakke
            90078513
              Det er godt mulig du har korrekt, jeg googlet bare og fant en passende indoorvideo
              Praktisk sak synes jeg det ser ut som. Er spent på hvor rigid den er og om servoer etc holder mål
                Skal ha sånn. Basta bom
                  Re: Parkzone VisionAire AS3X BNF testes for Smallsize!
                  Bare venter på pakke i posten jeg...
                  Alf
                    MARTIN! Fyll lageret deres, det her kommer til å gå unna!
                      Jeg har i alle fall bestilt
                        Friendly Airplane, som han sa. Det liker jeg å høre. Dette er nok standarden om kort tid.
                        Vennlig Hilsen
                          Rask oppakking, er nok montert på maks 15 minutter...
ID:	597137 Click image for larger version
ID:	597151 Click image for larger version
ID:	597153 Click image for larger version
ID:	597155 Click image for larger version
ID:	597157 Click image for larger version
ID:	597149 Click image for larger version
ID:	597147 Click image for larger version
ID:	597139 Click image for larger version
ID:	597141 Click image for larger version
ID:	597143 Click image for larger version
ID:	597145 Click image for larger version
                            du kan si hva du vil, men jeg håper og tror dette er en god hagemodell.
                            Har bestilt, og nå er det bare ventinga som gjenstår...
                              Den skal jaggu flys i hagen i morgen så får vi se, gleder meg til å teste!
                              Ser og føles ganske solid ut!
