Da er den på vei i posten og sett ut fra manual og bilder så bør den være maidenklar i løpet av meget få dager. Litt info fra Elefun og Pilot-RC også kommer det mer bilder/oppsett etterhvert.
Trainer i kjent Pilot-RC kvalitet, beregnet på nybegynnere og de som ønsker seg en stor, velflyvende modell med bensinmotor til f.eks sleping av seilfly. Kommer i stor grad av ferdigstillelse, og er trukket i original Oracover.
Fra Pilot-RC:
Self-correcting high-wing, Thick semi symmetrical airfoil design, more stable for beginner. • Special strong design landing gear mounting. Very durable with bad landing.
• Covered with Oracover(Ultracote ) from Germany
• Two piece plug-in wing. Transporting will be much easier.
• Option flaps, just a few minutes to split the aileron to be with flaps.
• Both tri-cycle landing gear and tail dragger included! You can choose tri-cycle or tail dragger.
• Repairing wood for the front of fuselage included! Most damage is the head of fuselage, firewall, landing gear mounting, we include the pre-cut wood for these area, it is more easy to repair now. Buy one , Get two!
• Design for towing glider. Just take a few minutes to install option towing release system(sell separately, can not tow large glider).
• Strong anodized aluminum landing gear, Option for the steel wire to reinforce.
• Design for both Electric motor and 20~35cc gasoline engine
• All necessary hardware included
• Plastic spinner included
• Factory installed fuel tank with fuel tube
• Factory installed fuel dot
• Installed rods with high quality ball-link.
• Servo wire clips included
• Servo extension wire for aileron, rudder and elevator included.
Vingespenn | 229cm |
Lengde kropp | 148cm |
Vekt | 4.2kg |
Motor | 20-30cc |
Servoer | 5 standard metallgir (4-6kg) |
- Selvkorrigerende semi-symmetrisk vingeprofil
- Spesielt sterkt understell for røffe landinger (forsterkningswire er ikke inkludert)
- To-delt vinge for enklere transport
- Kan enkelt settes opp med flaps dersom ønskelig
- Hale- eller nesehjul, begge er inkludert!
- Eksta treverk for reparering av de vanligste skadene er inkludert
- Muligheter for utløsermekanisme for sleping (ikke inkludert)
- All hardware inkludert
- Plastikk spinner inkludert
- Ferdig installert tank med fuelpåfylling og slange
- Ferdige linker med kvalitets kulelink.
- Servoforlengerkabel for alle ror og sikkerhetsklips er inkludert.
Fra Pilot-RC:
