For de som kjenner til Alexmos gimbal kontroller så har det nå akkurat blitt sluppet en ny sterk konkurent. Tre akset stabilisert med automatisk tuning som sparer timesvis med PID justering og som visstnok fungerer meget bra.
Skal montere mitt testkort i Tarot 960 med InfinityM gimbal og Sony Nex 5n kamera.
What makes Centerpiece your next gimbal controller?
Fully Automatic Tuning
Zero operator intervention needed in setup phase. Complete plug and play. Sensor orientation, PID parameters and motor power as well as other proprietary tuning parameters are deduced by the firmware at the end of an automated setup process (typically taking a minute to complete).
CANBUS Interconnects
CANBUS communication between the IMU and the main board ensures reliable, high-throughput, low-latency communication at hostile environments, even when motors are driven with 40v or more. CANBUS also enables unprecedented system scalability, with multiple parallel IMU and additional interface units.
Dual IMU Support (19 Axis Sensing)
Choice of single or dual IMU, each equipped with 9DoF sensing (gyro, accelerometer, compass). All components onboard the IMU communicate with the IMU processor using a high-throughput SPI bus. In addition, the main controller is equipped with an onboard barometer.
Dual/Triple Processor, Low Latency Architecture
The Centerpiece architecture uses a dedicated CPU for motor drive and motion control DSP algorithms. A separate CPU on the sensor unit drives the attitude estimation and sensor filtering algorithms. This yields an extremely low latency operation, even with our computationally demanding algorithms. Our architecture also ensures perfect parallelism when two IMUs are being utilized.
Operation At Any Angle
Whether operated with single or dual IMU, CP algorithms compensate for gimbal tilt at any angle (even operating inverted).
Fully Independent Cinematic Follow Modes
Proprietary cinematic algorithms for smooth operator/vehicle follow can be enabled for each axis, completely independently of each other.
Active Vibration Damping
The Centerpiece uses specially developed DSP algorithms for realtime vibration detection and cancellation.
Absolute Heading Reference
The use of compass in the IMU allows drift-free absolute position hold on all axes, including yaw.
Onboard Setup Interface
The Centerpiece is equipped with a strip of 5 bicolor LEDs, two flanking buttons and a buzzer to enable simple configuration changes in the field without using any external device.
Flexible Connectivity
Dual Spektrum satellite inputs, Futaba SBUS in/out and 4 in + 4 in/out PWM ports ensure unmatched connectivity. The Centerpiece supports a fully assignable 16 channel matrix on all I/O interfaces (the operator can freely mix Spektrum, SBUS and PWM).
Precise Battery Voltage Compensation
High resolution battery voltage compensation ensures constant drive at any point during flight.
hmm veldig interesant. sitter å vurderer en alexmos basert gimal eller en dji zenmuse til DJI S900 copteret mitt. Zenmuse skal være plug and play. men da kun til en type kamera, Men alexmos kan man bruke forskjellige kontrollere til. og heller balansere gimbal etter forskjellige kameraer/linser. når får du denne og skal begynne å teste?
carl goldberg ultimate
DJI S900
piper pawnie el kjærre
Kom i posten i dag, håper jeg får satt den opp og har endel klart i løpet av uka. Bakvakt på jobb så litt usikkert hvor mye tid jeg får til det. Men siden det står en Alexmos der fra før så er monteringen ganske enkel da det er samme monteringshull selv om Robotics kortet er litt større
Burde loddet inn kapasitatorer for lenge siden siden det er lange wirere til escs, men fikk endelig litt motivasjon. Nå er de på plass og Phobotic kortet skal inn i morgen
tenkte jeg skulle gå for denne med en tredje akse.http://www.grousehousetechnologies.c..._12829920.aspx. billigere enn zenmuse.. og med alexmos controller frem til den du har fått deg er testet ut og da eventuelt bestille da.. men da pro versjonen av den
DJI S900
ikke galt dette.. og ei heller lett å sette kamera opp i slikt lys. kjøpt meg en nex5t selv i dag for å bruke i en arris gimbal som skal ha phobotic etterhvert.. Men siden jeg er noob på kamera settinger.. fint om du kunne delt noen innstillinger på kameraet..
DJI S900
