- Added new screens to support Sound Categories. These allow you to select sounds more easily by grouping them into user-editable lists (categories) to reduce scrolling needed to find the sound you want. The radio supports up to 16 categories; this update will create default categories but you can modify or remove them as you desire.
- The pre-flight checklist shows the name of the model on power-up. This allows you to verify the right model is being started without having to go through the complete list first.
- New trainer mode “FPV” added to allow head tracker inputs to be mapped to any channel, with adjustable scaling and reversing. This mode enables easy mapping of head tracker channels to receiver ports, while not affecting flight controls. It supports both wired and wireless head trackers.
- Add support for Flight Pack Capacity (mAh) and Receiver Pack Capacity (mAh) sensors
- ]Add support for ESC sensor
- X-Plus channels are now able to be configured to generate warnings in 18-
channel systems, in addition to the normal channels previously available - On the Model Copy utility, you are now able to select the Source model for
copying. It is no longer necessary to use Model Select first. - When setting up a timer, a 20-second alert is now available.
- You can now use the “wiggle” function to select analog inputs when entering a
“switch” option. Just move the appropriate switch or stick or slider and it will
select it automatically. - Trainer input is now more tolerant of inputs from devices such as head trackers
Corrections- .AS3X Gains telemetry screen does not show when configured to not show.
- Custom Voice Events of 16 steps now advance properly.
- Sailplane AIL>RUD mix field “Sub Switch” is now exported properly.
- Heli gyro trim values are aligned properly for all flight modes
- Heli trim setup screen operates properly in tray radios
- Digital Switch Setup does not allow selection of Flight Mode switch if the Flight Mode system is not configured.
- Vario volume is now exported and imported properly.
- Trainer inputs are not allowed to exceed Absolute Travel settings.
- Corrected delay between tx voltage status announcements
- Telemetry screens now refer to Turbine rather than JetCat.
- Telemetry screens with trim displays now properly indicate centered status the
same as the main screen. - Sequencers and Gyros will now properly release a channel when being turned
off. Note that you must completely disable the gyro for the old channel name and function to be fully restored. That is, you must set the Gain input (first screen) to INH, click NEXT, then set the mix to INH > INH, then the switch to INH. Only then will the channel be completely and properly freed up. For sequencers you only need to set the output channel to INH. - “Tone” selection for inactivity alarm now operates properly. Audio System Change
- Added support for more audio file types.
- Thousands is spoken correctly in English.
- When setting up custom sound events, the active switch position for steps and
reset on sequenced events is utilized properly. - New sounds have been added to the list
- Spanish speech has consistent volume level.
