Originally posted by kjetilmh
View Post
"The Throttle-Tech system can go to 15S or even higher, but will require a new LiPo Tap board layout to be compatible with the higher voltage. I'm just curious, how high in cell count do you see this going in the future?
For the near term, I think I can accommodate a 15S configuration, but it will have to be done on a customized basis. I'll put one together and try it this weekend, then I can get back to you about availability in the near term.
Thank you and best regards,
Ed Alt
Så da venter jeg bare på en tilbakemelding på hvordan testen på 15S går Knall bra!
