HobbyWing PLATINUM 120A-HV-PRO Programmable High-Voltage Brushless ESC for Aircraft and Helicopter, ESC-en er som ny kun vært test på et fly, og den ble for stor for holde den flyet jeg har, derfor må selge den. Det er EC5 kontakt på , og har forlenge den ene ledningen litt lengre med en JST-kontakt i mellom, medfølge RPM sensor og bruksanvisningen.Kjøperen betale frakt, kan sende den som brev hvis kjøperen ønsker for egen ansvar.This Brushless ESC is for aircraft and helicopter use and is suitable for both in-runner and out-runner brushless motors. It features start-up failure protection, over-heat protection and throttle signal loss protection.Features:* Manufactured using high quality components* High performance microprocessor for the best compatibility with all brushless motors* Efficient heat-sink design for optimum heat dissipation* Factory fitted anti-spark device to prevent sparking when connecting high cell count batteries* Three start modes providing for both fixed wing aircraft and helicopters: normal, soft, very-soft* Smooth, linear, quick and precise throttle response* Multiple protection features: Low-voltage cut-off protection, over-heat protection, throttle signal loss protection* Governor mode for helicopters* Maximum motor speeds: 210,000rpm (2 poles), 70,000rpm (6 poles), 35,000rpm (12 poles)* User programmable via the transmitter, digital LED program card, advanced professional LCD program box or PC software* Firmware is upgradeable using the optional USB adapter on the Professional LCD Program BoxSpecification:Series Platinum ProModel 120A HV-OPTOApplication : Aeroplane/HeliConstant current: 120A Burst current: 180ABEC Mode: n/aBEC Output: n/aBattery Cell Count Lipo : 5-12SBattery Cell Count NiMH: 15-36Weight 125gLength (mm) 88Width (mm) 55Height (mm) 15
More...
More...
