Vurderer å selge en Snipe DLG fra Vladimirs. Dette er en F3K modell av ypperste klasse og den flyr helt fantastisk. Modellen fremstår i utmerket stand og er av de absolutt letteste på markedet, under 215 gram flyklar! (Nypris 680 Euro + frakt/avgifter).Selges fordi jeg har to stk og dessverre altfor lite tid til å fly ;- )Kontakt email: rotel123@hotmail.com eller tlf: 41325920Informasjon fra leverandør:F3K World Champion Joe Wurts, using his experience as an competitor and aerodynamicist, designed his ideal DLG - the Snipe. The Snipe features both new technology and a design driven by his years of experience in DLG competitions. The design incorporates a high-aspect wing and new airfoils to yield superior launches and long legs to chase those far away thermals.Features:Wing - Full spreadtow carbon (SC) CarboLine 39 skins manufactured using new molding technology provide superior strength and stiffness. This process also produces a hard wing skin of foam that is stable and immune to temperature changes. Wing Mount - A wing mount employs a cone-shaped mating surface which securely locks the wing to the fuselage with lightly torqued fasteners. High launch stresses are spread over the large cone surface instead of small crush-prone bolt openings. The main front wing mount is made from high strength carbon fiber with an embedded aluminum washer.Airfoil - The Snipe features a new series of proprietary high performance airfoils designed by Joe Wurts.Streamlined Pod - A removable nose cone on the stream-lined pod easily provides access to RC gear & ballast.Tail Boom - A single unit tube design saves weight while yielding a stronger structure. A full-length carbon-fiber tube transfers the load of the ground impact without stressing the nose cone. The wing is directly attached to this tube..Rudder - An asymmetrical rudder provides a superior response during slow flight.Horizontal Stab - The stab is mounted below the boom, allowing for better pull/spring setup.Ballast Provision - The Snipe utilizes the same ballast system as the Blaster 3. A lightweight ballast on-a-stick system inside the fuselage allows for the addition of ballast. Wingspan : 1490mmLength: 1086mm Profil : Joe WurtzWingarea: 19.65 dm²
More...
More...
