Viser resultatene 1 til 1 av 1
  1. #1
    Ble medlem
    May 2014
    Innlegg
    51
    Post Thanks / Like
    Thanks
    2
    Kraft
    0
    Standard Volantex Sbach 342
    Har en Volantex Sbach 342 liggende i original esken. Aldri fått tid til RC hobbyen.
    Rettelse: Trudde jeg hadde RTF modellen, men det er PNP modellen.
    Selges for 1200kr.
    Kan kontaktes på 48322568
    Features:
    Good 3D manuaver
    Light and durable EPO construction
    Easy to assemble
    Specifications:
    Wingspan: 1100mm (43.3 in)
    Overall Length: 1115mm (43.9 in)
    Flying Weight: 1100g
    Prop Size: 1260 propeller
    Motor Size: 4023 Powerful brushless motor
    Speed Control : Easy-Plug 40A Switch-Mode BEC brushless ESC
    Servo 9-gram Servo * 2pcs, 17-gram Servo*2pcs
    Recommended Battery: 11.1V 1800mAh ~ 2500mAh 25~30C Li-Po (not included)
    Charger: 3S LiPo balancing charger, 0.5A (not included)
    Flaps: No
    Retracts: No
    Radio: 2.4Ghz 6-Channels (not included)
    Minimum Age Recommendation: 14 years
    Experience Level: Beginner
    Recommended Environment: Outdoor
    Assembly Time: Less than Half Hour
    Is Assembly Required: Yes
    Navn:		756-1-Sbach342-05.jpg
Visninger:	19
Størrelse:	63,2 KB
    Sist endret av KennethLNOR; 17-05-17 kl 20:22
Lignende tråder
  1. Dynam Sbach 342 RTF
    Svar: 0
    Siste melding: 05-01-17, 12:34
  2. PilotRc Sbach 342 40%
    Svar: 0
    Siste melding: 05-12-14, 14:10
  3. PilotRc Sbach 342 40%
    Svar: 0
    Siste melding: 07-11-14, 12:40
  4. PilotRc Sbach 342 40%
    Svar: 0
    Siste melding: 17-10-14, 01:15
  5. Sbach 342
    Svar: 0
    Siste melding: 26-04-14, 22:50
Regler for innlegg
Annonse
Annonse
Annonse
hosted by EasyISP.no
