Selger en 14 kanals 2.4 ghz mottaker type Futaba R6014HS. Kun brukt noen få ganger og fremstår som ny. Selges kr 950.Detaljer:14 kanals 2,4G mottaker FASST FEATURES: Simple one-touch linking - no plugs to mess with or loseA full range system for all aircraft from giant scale to Park Flyer applications-no need to buy separate receiver for specific aircraft.Two operation modes; Normal, frame rate of 14ms accepts any type ofservos and High Speed with a frame rate of 7ms for digital servos including the Futaba BLS servos.High Speed on channels 1 through 6.Dual Antenna Diversity allows 2.4GHz FASST Futaba transmitter selects the best reception between the two receiver antennas withno signal loss.Rubber grommets installed where antennas exit eliminates stress andfraying of the two antenna wires.SPECS: Power Requirement: 4.8 - 6VDimensions: 1.48 x 2.05 x 0.63" (37.6 x 52 x 15.9mm)Weight: 0.76oz (21.5g)
More...
More...
