Jeti DS 24 i hus! [emoji2][emoji106]
  • Jeti DS 24 i hus! [emoji2][emoji106]
    Endelig er nye Jeti DS 24 i hus. Dark red utgave da jeg ikke orket å vente ennå lenger på andre varianter.
    Kjapp levering fra Autopartner når de først var tilgjengelig.
    404 - Allt inom radiostyrt - Autopartner.se
    Og KUN 19 operative fly som skal over på denne så da går det vel litt tid da [emoji25][emoji3][emoji6]
      Eeey! Grattis!
      Hva er forskjellen fra DS16 bortsett fra fargedisplay og antall kanaler?
        Min grunn til å bytte var minnet. DS 16 gir også 24 kanaler men minnet i DS 16 er svært begrensende i forhold til telemetri som jeg ønsker ifbm telemetri på twin turbin Me 262.
        Changes between DS-16 and DS-24
        We do have to keep one thing in mind. DC-24 is about ready, DS-24 will be available with present knowledge in Q3/Q4 of 2016 so something might still change.
        If we go through the specifications we can find following:
        • 24 proportional channels (Well, DS-16 got these with FW 4.00 but anyway)
        • 900MHz system, (863 – 879MHz in EU) added redundancy on a totally different frequency
        • 30 free mixes (DS-16 has 20)
        • Audio player now support’s Mp3-files
        • FM-radio
        • Microphone to record own audio-files
        • Vibrating sticks (“Haptic feedback”)
        • Color-display
        • Possibility to have background-picture of (for example) the model (Yes, catwalk-models do apply too!)
        • 24 logical switches (DS-16 has 16)
        • 24 direct inputs (DS-16 has 16)
        • 16 telemetry devices (DS-16 has Note: This means units, not values!
        • 40 sounds on events (DS-16 has 20)
        • 64 telemetry values shown on display (DS-16 has 32)
        • 8Gb SD-card from factory (DS-16 has 4Gb)
        There are some other minor differences. The screen is 320x240px in both DS-16 and DS-24 but in the DS-24 it is 3,5″ when it was 3,8″ in DS-16. The difference will almost be unnoticed by most of us, we just see it as “more precise” sense DPI will be little bit higher.
        Since there are 3 transmitter-modules there will be five antennas, 2+2 for 2,4GHz and 1 for 900MHz. The battery is the 5200mAh Li-Ion we all know already, in my experience this is more than plenty. Of course the color-display will take a bit more power but I really do not see this as any issue whatsoever.
        Measurements and form-factor is exactly the same, also the weight stays at the same 1,25kg.
          Det var FM-radioen som gjorde utslaget, tenker jeg..
            Skal nyte en god lokalradio 🤣[emoji16]
