*ustartet* modell proppet med high-end utstyr. Product Specifications Wingspan: 89.0 in (2,260mm) Overall Length: 86.0 inches plus spinner length Wing Area: 2,490 sq in (161 sq dm) Flying Weight: 26.0–28.0 lb (12.0–13.0 kg) 1 x Hangar9 Beast 1 x Desert Aircraft 120 (DA120) 7 x JR DS8921HV 2s LiPo 36.5kg 72g (Alle rorflater) 1 x JR DS8925HV High Voltage Servo (Throttle) 2 x 6,6V 2100mAh - 5C - Hyperion LiFe Receiver Pack (Rx) 1 x 6,6V 1600mAh - 5C - Hyperion LiFe Receiver Pack (tenning) 1 x Futaba SBS-01T Temperature Sensor 18MZ 14SG 1 x Futaba Optical RPM Sensor Unit Telemetry S.BUS2 1 x MTW Canisters Complete set for Beast 1 x DPSI 2018 Servoer har kun hatt strøm for sentrering. Motor har aldri vært startet Gjenstår å montere wire på hale + et par servokontakter. Kan vurdere å slakte for salg...
More...
More...
