Mejzlik 27x10 TH (2 blade)
  • Mejzlik 27x10 TH (2 blade)
    A great performance prop that features hollow blades, fabricated from uni-directional and bi-directional carbon fiber and epoxy.Very light, super strong, with a solid hub area allowing them to be drilled for Multi bolt hubs.The finish is a beautiful high gloss, clear epoxy gel-coat over black woven carbon fiber.Factory balanced.The hub is drilled on its center for a 10mm bolt.Drilled for 3W hubs.Weight: 259g approx.TH=Thin profile
    More...
