Har nettopp lagt ut en post på RCU
Side thrust and down thrust on a patternplane - RCU Forums.
Tar gjerne imot tips og hint her også.
Sjekk gjerne denne linken: http://www.rcuniverse.com/forum/m_90.../tm.htm#902451
Mitt innlegg på RCU:
I have a well built Patternplane designed by a friend. Fuselage 195cm, w.span 185cm
It used to have a OS 108FSR (BX1) with a Macs Pipe.
The plane (4,5kg) felt a little underpowered, especially on the tophat and the square loops.
I have now bougth a OS 140 rx that i plan to prop with a 17x12APC. I have now built a DIY Hyde mount and got a DIY nosering made. (http://home.online.no/~ofremmi/HowTo.../HydeMount.htm) thanks Ola
I am now in the process of lining things up and plan to have 2,5 to 3 degrees sidethrust, but I am wondering about skipping the down thrust and instead add a throttle to elevator mix to help on the uplines and downlines.
Has anyone has tried this on a real patternplane, and what effect did you get?
I have a 90 size patternplane where I have about 1 washer of down trust, and ended up with -1% throttle to elevator mix( -1%elevator at idle) to make the downline straight (instead of pulling to the belly.)
All comments and hints are apreciated,hell we might get a good discussion going....
