Parkzone Vapor ultralett fly
  • Parkzone Vapor ultralett fly
    Modellflynytt får denne lille lette modellen neste uke når nytt parti kommer inn. Har du lite areal og fingra klør etter å fly så kan dette være noe for deg. Modellen kommer RTF og alt du trenger er med. Dessuten følger det med 2.4 GHz sender, alternativt kan flyet bindes opp mot din eksisterende Spektrum radio.
    Info fra produsent:
    Wingspan: 14.75 in (375mm)
    Overall Length: 15.25 in (387mm)
    Flying Weight: 0.5 oz (15 g)
    Radio: 3-channel 2.4GHz w/Spektrum DSM2 technology (included)
    CG (center of gravity): Front wing mount 23mm back from front edge of fuselage; battery tray 13mm back from front wing mount
    Recommended Battery: 3.7V 70mAh Li-Po battery (included)
    Charger: DC single-cell Li-Po
    Minimum Age Recommendation: 14 years
    Experience Level: Intermediate
    Recommended Environment: Indoor
    Assembly Time: Less than 1 Hour
    Is Assembly Required: No
    Mer info:
    * Compatible with all transmitters using DSM2™ technology
    * Can be flown almost anywhere—a living room, a basement, even a garage
    * Slow-flying innovation and ultra-compact size help you perform incredible indoor maneuvers
    * Everything except the transmitter is included
    * Micro 3.7V 70mAh LiPo battery
    * Single-cell LiPo charger safely and conveniently charges the battery in approximately 20 minutes
    * Great looking without any gluing or painting required
    * Throttle, rudder and elevator provide true 3-channel flight and maneuverability
    * Fully proportional, super lightweight servo motors with feedback potentiometers for precise control
    * Fuselage and tail/wing framework made of lightweight carbon; wing and tail surfaces covered in lightweight and durable PET film
    * Also available in a RTF version (PKZ3300)
    Compatible with any Spektrum™ DSM2™ transmitter, the Vapor™ is a stylish Bind-N-Fly™ plane that offers pilots a one-of-a-kind indoor experience. As ParkZone’s slowest and lightest fixed-wing aircraft, it can be flown almost anywhere—a living room, a basement, even a conference room at work. Incredibly compact and loaded with all of RC’s best innovations, owners of DSM2 transmitters (including the DSM2 radio utilized by E-flite’s Blade® CX2) can have the Vapor airborne in no time, making it the perfect alternative for those times when you can’t make it out to a park or flying field.
    The Vapor is the second member of ParkZone’s tremendous Etomic™ family of ultra-micro aircraft. Its carbon fiber composition represents the ultimate in lightweight design, helping it deliver the best in flight quality, value and, most importantly, fun. Its single-cell LiPo battery charges in approximately 20 minutes and gives you extended flight times of nearly 15 minutes, while 3-channel control provides the precision needed for flying in those tight spaces indoors. All you need to do is bind your DSM2 transmitter and your adventure into the new era of RC flight begins.
    Amazingly easy to fly, the Vapor features the state-of-the-art looks and reliability people love about ParkZone products, making it a unique addition to your fleet.
    Hvilken butikk skal forhandle denne modellen? også står det at sender ikke følger med. Men gjør den det? Spennende prosjekt.......
      Det er www.smallsize.no som selger disse.
      Den komme ri 2 varianter med og uten sender. For de som selges uten sender kan den bindes mot alle andre Spektrum radioer
        Okei.Takk. Da blir det vel mer kjøping snart selv om kjellern er full hehe
