Blade mCX RTF
  • Blade mCX RTF
    Smallsize har vært skikkelig på hugget i sommer og har masse testartikler som skal prøves hos MFN i høst. Helikopteret er litet og kommer i fluoriserende materiale som gjør at den lyser på kvelden. Hva med å lyse opp innendørshallen i vintermørket??
    Selges hos www.smallsize.no
    Her er siste skudd på Blade stammen:
    Blade mCX RTF
    The Blade® mCX is an ultra micro-sized version of the Blade CX/CX2, offering first-time pilots the ability to learn how to fly with ease and experienced heli pilots the ability to fly anytime, anywhere indoors. The Blade mCX offers unsurpassed stability and incredible control through the coaxial, counter-rotating head design and Spektrum™ 2.4GHz DSM2™ control. And, thanks to its rotor span of just 7.5 inches and one-ounce flying weight, the Blade mCX can be flown indoors almost anywhere—from an office to a small bedroom or living room.
    The Blade mCX comes 100% factory-assembled, flight-tested and ready to fly right out of the box—no assembly or setup required. Included in the box is the Li-Po battery and convenient AA battery-powered DC Li-Po charger, 4-channel transmitter equipped with Spektrum 2.4GHz DSM2 technology, and 8 AA batteries (4 for the transmitter, 4 for the charger). The DSM2 technology offers freedom from frequency restrictions and allows the Blade mCX to be flown anywhere, anytime indoors with precise 4-channel control.
    When it comes to ultra-micro heli fun everyone can enjoy, you simply can’t beat the value and performance of the Blade mCX. It’s just another way E-flite is advancing electric flight.
    Also available in a Bind-N-Fly™ version (EFLH2280)
    Key Features
    • 100% factory-assembled, test-flown and ready-to-fly right from the box
    • Includes everything needed to fly—there's nothing extra to buy
    • Ultra-micro size and weight perfect for indoor flying
    • Innovative airframe design and electronic components offer incredible durability and precise control for excellent manueverability
    • Coaxial, counter-rotating rotor head design for unsurpassed stability and ease of flight
    • 4-channel transmitter equipped with Spektrum™ 2.4GHz DSM2™ technology, digital trims and dual rates
    • Factory-installed 5-in-1 control unit with Spektrum 2.4GHz DSM2 compatible receiver, main motor ESCs, mixer, gyro and fully proportional servos
    Product Specifications
    Type: Ultra Micro Coaxial Helicopter
    Main Rotor Diameter: 7.5 in (190mm)
    Gross Weight: With Battery 1.0 oz (28 g)
    Length: 7.9 in (200mm); Height: 4.7 in (120mm)
    Motor Size: Micro Coreless (2 installed)
    Kit/ARF/RTF: RTF
    Experience Level: No Experience Necessary
    Recommended Environment: Indoor
    Is Assembly Required: No
    Test tråden her:
    http://www.modellflynytt.no/showthre...d=1#post194871
