ETS Guardian 2D/3D Stabilizer - elefun.no - Radiostyrt hobby
Elefun har fått inn ny duppedings som må testes:
Gyrostabilisering for alle typer fly! Liten og lett enhet for enkel installasjon. Kan benyttes i 2D og 3D modus, med opp til 4 kontrollerte servoer. Justeringer gjøres med skrujern eller via USB (micro USB kabel følger ikke med). Dataport er bygget inn og senere softwareoppdateringer vil gi enda flere muligheter.
[LIST]Based on Eagle Tree´s proven inertial stabilization technology, the Guardian 2D/3D Stabilizer is a must-have product for your model. The Guardian smoothes out air turbulence, but does much more. Unlike cheap ?gyro stabilizers," it provides true wing leveling capability to help recover from lost orientation!
Whether you fly gas or electric models, wings, foamies, sailplanes, or just about any other fixed wing model, the Guardian is for you! Is it moderately gusty or windy? The Guardian helps compensate for non-ideal flying conditions. The Guardian helps your plane fly like it´s a perfectly calm day!
To stabilize your model, just mount the Guardian in a level orientation (it can even be mounted upside down), connect it to your servos and receiver with the included cable, tune it to your plane with a small screwdriver, and set optional features with your radio sticks. No computer or additional equipment is required for stabilization.
While in flight, a spare switch on your radio lets you switch between 2D (wing leveling) mode, 3D aerobatic mode, and no stabilization. Imagine performing a difficult 3D maneuver with ease, then just flipping a switch to instantly return to level flight!
In 2D flight mode, the Guardian provides much smoother flight and wing leveling stabilization for your model, which makes it a lot easier to adjust and fly your plane. The Guardian "remembers" level flight for your model and returns it to level flight when needed, as well as providing precise "fly by wire" control. You may think that your model is on rails! The Guardian is also great for FPV flying.
If you are a beginner pilot, the Guardian can help take the fear factor out of the first few flights. If you get into trouble, just let the sticks go and the Guardian will attempt to quickly bring your model back to level flight.
If you are flying a plane that is not very stable due to imbalance, poor aerodynamics or high motor torque, the Guardian can make things much easier.
In 3D flight mode, the Guardian becomes your aerobatic assistant. Whether you want to become a 3D expert, or already are, the Guardian can turn your squirrelly stunt plane into a kitten, without sacrificing aerobatic capability.
The Guardian updates your control surfaces much faster than most humans can, to provide real time corrections to the flight. So, you can concentrate on your maneuver, rather than fighting the model to maintain control. The Guardian makes your plane "snappier" for precision maneuvers.
The Guardian has two submodes for 3D flying:
In 3D Heading Lock submode, simply center your sticks to have the Guardian lock onto your present attitude (pitch, roll, and heading), which can make it easier to perform stunts like prop hanging, inverted flight, knife edges, low speed harriers, etc!
In 3D Gyro submode, the Guardian uses its built-in 3 axis gyro to increase your model?s stability, while leaving you in full control. In this mode the Guardian greatly reduces the effects of gusts, turbulence, motor torque and other factors, and can expand the maneuverability of your model in a variety of conditions.
