T-REX 450XL ccpm version Kit
Kommer på lager uke 31
Features
1.Auto-Rotation System
2.Rear Tail Servo Mount
3.Collective Pitch System
4.Tail Rotor Drive Belt System
5.Main Drive Gear with Cooling Fan
6.35 Precision Bearings
Specification
-Length:650mm
-Height:230mm
-Main Rotor:680/700mm
-Tail Rotor:150mm
-Motor Gear:15T/13T/11T
-Main Gear:150T
-Autorotation Tail Drive Gear:109T
-Tail Drive Gear:22T
-Drive Gear Ratio:
1:10:4.95/1:11.5:4.95/1:13.6:4.95
-Weight(without power system):325/345g
-Weight(including power system):About 610-650g
Accessories
-T-REX 450XL Kits SetX1 set
-Fiber Rotor Blade(325x32mm)X1 set
-Aluminum CaseX1
-RCM-BL25T 25A Brushless ESCX1
-420LF Brushless motor(3200KV)X1
Kun kr 2.395,-
www.xmode.no
Features
Specification
-Length:650mm
-Height:230mm
-Tail Rotor:150mm
-Main Gear:150T
-Drive Gear Ratio:
Accessories
-Aluminum CaseX1
Kun kr 2.395,-
www.xmode.no
