More...
Spektrum DX8
Spektrum DX8
Selger en Spektrum DX8. Følger med telemetri enhet, lader, nakkestropp, 8 kanaler som mangler satellitt og 2 Orange mottakere.Key FeaturesHigh-speed 11ms frame rate with 2048 resolutionLarge 128 x 64 backlit screen30-model internal memoryElectronic E-ring electronically prevents overdriving the cyclic servosSpektrum Data Interface provides expanded model memory, model sharing, and firmware update capability 8 Wing Types and 5 Tail Types are available for nearly all aircraft typesActive gain and governor trim allows for in-flight adjustment of the gyro gain and RPMProgrammable Flap System with Flap Delay and elevator compensationProgrammable Telemetry Warnings provides both tone and/or vibration alerts4 Swashplate TypesSimpleScroll roller provides easy menu navigationUser-assigned switch functionProgrammable Throttle Cut FunctionIncludes TM1000 Full Range Telemetry Module providing real-time Flight Log data, receiver voltage, flight pack voltage, RPM and temperatureExclusive AirWare? Software offers advanced features that are easy to useRefined ergonomics with no-slip comfort gripsProgrammable timer with throttle timer startupQuad bearing gimbalsOverviewCombining Spektrum? industry-leading 2.4GHz DSM® technology with real-time telemetry in this DX8 represents a breakthrough in 8-channel sport-level radio systems. The telemetry module is expandable based on the module needs; the module is capable of supporting Quality of Signal (Antenna Fades, Frame losses, holds), Receiver Pack Voltage, RPM, Temperature and Flight Pack Voltage. Enthusiasts can add the safety of real-time telemetry and monitor vital aircraft stats right from their transmitter without any additional equipment. Keep your engine operating in the optimum temperature range, keep an eye on your battery voltage, and check out just how fast your aircraft is running all right from the large LCD readout of the DX8.Always purchase products from a Horizon Hobby, Inc. authorized dealer to ensure authentic high-quality Spektrum product. Horizon Hobby, Inc. disclaims all support and warranty with regards, but not limited to, compatibility and performance 8kSpecs# of Channels: 8Modulation: DSM2/DSMXBand: 2.4GHzProgramming Features: Airplane and HeliModel Memory: 30
More...Tags: None
