Xaircraft Xcope FPV på lager hos www.tktrading.no
  • Xaircraft Xcope FPV på lager hos www.tktrading.no
    Xcope with SuperX-Basic
    Designed for FPV
    Xcope features a pre built carbon fibre airframe, and combines a single axis camera mount up front. Strap on your favourite digital sports camera and explore the world through FPV (data link and viewing equipment not included). The frame folds down to an extremely small size, allowing you to take Xcope everywhere you desire. With our SuperX Flight Controller at its core, Xcope is designed for every level of experience. From new pilots to FPV racers, Xcope will adapt to your needs.
    Compact design, foldable for ease of storage and transport
    SuperX FC with firmware designed specifically for Xcope
    Single axis (tilt) action cam gimbal with auto stabilizing
    Under 1.5 Kg TOW (take off weight) with GoPro, battery and RX onboard
    ESC: 10 Amp ESC
    Motor: XAircraft T-Motor 2212-13 motor 920KV
    Propeller: APC 10 X 3.8 SF
    Included in package:
    Xcope frame and power units (motors, ESC's and blades)
    Super X Basic FC (includes GPS, compass, IO V2 module and Pilot Light).
    Other items required for flight sold separately:
    Battery: Requires 11.1V Lipo (3S) with minimum 20C discharge rate. 5000mAh provides approximately 15 minutes flight time.
    Lipo battery balance charger
    Transmitter and receiver
    FPV AV transmitter and receiver, and screen or goggles for viewing
    Kommer i to forskjellige pakker:
    1. 404 - Siden finnes ikke - T K TRADING Torbjørn Kristensen
    2. 404 - Siden finnes ikke - T K TRADING Torbjørn Kristensen
