Da var esken i hus med 450 utgaven fra SJM. Pre-build og motor og esc i kombo. Fikk tatt noen raske bilder i dag før jeg drar på langweekend. En lekker kobinasjon av metall og karbon. Det ser riktig lekkert ut.
Manualen ligger med for de som ønsker å kikke på denne.
http://www.sjmrc.us/pdf/SJM325SE_rm072008.pdf
Litt info om den her: http://www.micro-hobby.com/product_i...products_id=30
RC-TEK SJM325-C PRO V2 SE (PLUS) Highlights:
• NEW PRO Enhanced Rotor Head with Extended Pitch Range
• NEW Thrust Bearing Based Main Blade Grips
• NEW V2 Parallel Feathering Shaft System (Patent Pending)
• NEW V2 150mm 3D-PRO Tail Assembly
• NEW V2 15x367mm Carbon Fiber Tail Boom
• NEW V2 125T Main Drive Gear
• NEW V2 Direct Tail Drive Belt System
• NEW V2 SJM Plastic Main, Flybar, and Tail Blade Sets
• FREE 59.5mm K&B High Performance Tail Blades
• FREE RC-TEK 325mm PRO Carbon Fiber Main Blades
• NEW V2 100% 3K Carbon Fiber Air Frame
• NEW V2 Precision Polished CNC ALU Components
• NEW V2 Durable Round Plastic Canopy
SJM325-C PRO V2 SE (PLUS) Specifications:
• Airframe Weight (Including Canopy and Main Blades): 505g
• RTF Weight: 775-875g
• Airframe Length (With Canopy): 710mm
• Airframe Width: 120mm
• Airframe Height: 220mm
• Main Blade Disk Diameter: Up to 760mm (Using 330mm Main Blades)
• Flybar Paddle Disk Diameter (RC-TEK Default): 350mm
• Flybar Rod Size (RC-TEK Default): Ø2.5mm x 240mm
• Tail Rotor Disk Diameter: 150mm (Using 58mm Tail Blades)
• Main Shaft Size: Ø6mm x 136mm
• Tail Rotor Shaft Size: Ø3mm x 45mm
• Tail Boom Diameter (External): Ø15mm
• Main Drive Gear: M0.6 125T
• Main/Tail Gear Ratio: 1 : 4.82
Upgraded Power System Included With This Combo Kit:
• Brushless Motor: SJM-BM30 3000KV HP Outrunner (12T/13T Pinions Included)
• High Performance ESC: SJM40A (PRO) w/ 3A (5A max) 5V S-BEC
• Both the SJM motor and ESC are fully 11.1V~14.8V (3S/4S) ready!
Additional Features:
• 100% CNC Based Metal and Composite Material Product
• Main Rotor Tuning: Adjustable Screw Distance
• Adjustable Mixing Control
• Revolving Swash-Plate: CCPM 120 Degrees
• PRO Performance for Both Sport Flying and Competition
