Micro Beast fra www.el-fly.dk
    • 5876
    Det er mer stor glede (siden jeg jobber med den store Beast) at vi skal teste nye Beast UMX BNF fra www.el-fly.dk
    Legger ved litt spesifikasjoner fra Horizon:
    Key Features
    * Flies with the feeling of a larger scale aerobatic plane
    * Completely built and flight ready – just bind to any DSM2 aircraft transmitter with dual rates and expo
    * Equipped with a brushless 180 outrunner motor
    * Small enough for experienced pilots to fly in the backyard
    * Includes 2S Li-Po flight battery and DC Li-Po charger
    Overview
    Designed by aerobatic world champion Quique Somenzini, the Ultra Micro eXtreme (UMX) Beast® is a thrilling small-scale recreation of one of the most awe inspiring airplanes on the airshow circuit today. And, like the full-scale Beast, it delivers high-powered aerobatic excitement that will put a grin on the face of any intermediate to experienced RC pilot.
    At the heart of its phenomenal performance is a brushless motor, propeller and battery combination that delivers a spine-tingling thrust-to-weight ratio. This incredible power output, combined with its well-balanced controls and carbon reinforced wing, allow the UMX™ Beast to achieve a level of precision and performance that has more in common with its giant-scale Hangar 9® twin than any ultra micro you’ve flown before.
    The UMX Beast BNF comes completely assembled with a BL180 brushless outrunner motor and Spektrum AR6400LBL Ultra Micro DSM2 Receiver/BL ESC installed. Built-in long-throw servos on the AR6400LBL drive the elevator and rudder while two independent Spektrum AS2000L long-throw ultra micro servos drive the ailerons. A 2S 7.4V 120mAh 20C Li-Po battery and DC Li-Po charger are also included.
    Needed to Complete
    A 4+ Channel DSM2 Transmitter (with Dual Rates and Exponential programming recommended)
    Specs
    Wingspan: 14.7 in (374mm)
    Overall Length: 15.7 in (400mm)
    Wing Area: 83.8 sq in (5.40 sq dm)
    Flying Weight: 2.36 oz (67g)
    Motor Size: 180BL Brushless Outrunner, 2300Kv (included)
    Radio: AR6400LBL 6CH Brushless ESC Receiver (included)
    Trim Scheme Colors: Black, Red, Gold
    CG (center of gravity): 18mm from Leading Edge of Bottom Wing
    Prop Size: 5 x 2.75 in (127mm x 70mm)
    Recommended Battery: 2S 7.4V 120mAh Li-Po (included)
    Aileron: Yes
    Elevator: Yes
    Rudder: Yes
    Throttle: Yes
    Flaps: No
    Retracts: No
    Approx. Flying Duration: 5 minutes
    Scale: Ultra Micro
    Charger: Celectra 2S 7.4V DC Li-Po Charger (included)
    Steering: Yes
    Experience Level: Intermediate
    Recommended Environment: Indoor/Outdoor
    Is Assembly Required: No
    • 5876
    • orjanp
      • Nov 2007
      • 726
      Denne blir morsom å se.
      Ørjan Pettersen
      • Jostein
        • 1161
        Finner den ikke noe sted på sia til el-fly?
          • 5876
          Det er nok litt tidlig ennå. Er akkurat released fra Horizon.
          Jeg kommer med direktelink så fort den er der
            • 5876
              • 5876
              Sjekk all informasjon hos Electric Flight her!
              • Hansi79
                • Feb 2007
                • 587
                I find that a Ducks opinion of me is very much influence`d over whether or not i have bread with me
                • lowland
                  • 94
                  100 kroner billigere hvis du stikker innom smallsize. http://shop.smallsize.no/product_inf...aa85e9504a5d42 . Kjenner jeg fikk litt lyst til å innom der i morgen.
                  • GTI20
                    • Jul 2008
                    • 1426
                    så hvis man ikke har noe spektrum sender så er det ikke noe poeng i å kjøpe denne?..
                    carl goldberg ultimate
                    DJI S900
                    piper pawnie el kjærre
                    Futaba 14SG
                    diverse epp tjafs
                    Per-Egil Furuseth
                      Jeg har veteranene lyst på.
                      Har dx6i liggende ...
                      • ole.foll
                        • Apr 2005
                        • 1043
                        hm, kjipt hvis mottaker som følger med bare fungerer med spektrum sendere. Jeg har jr sender. Regner med jeg må bytte til en annen mottaker da. Noe forslag til hva man kan bruke evt?
                        Ole Kr Follstad
                        EF Extra 300 60"
                        EF Extra 300 104" Eme120
                        GB Yak 55 2,2m, Dle55RA
                        ESM Bearcat, NGH 38cc
                        Phoenix p51D Mustang, Dle55
                        Phoenix K8b, 1:2,5 6m
                        Hangar 9 Piper cub 1\4
                        Ask 21 1:3 5,7m helkompositt
                        • lowland
                          • 94
                          Jeg har en JR DSX9, den fungerer utmerket på Vapor, Blade msr, og sukhoien. Alle er BNF kjøpt fra smallsize
                            • 5876
                            Og min er satt opp på JR 12X, funker vel med alt av spektrum/JR DSM?
                            Sent from my Desire HD using Tapatalk
