Small Size Hobbyland AS
Fikk en hyggelig mail fra Frode hos Smallsize i dag med bekreftelse på at denne kommer til test i løpet av kort tid.
E-flite sitt første fly med thrust vectoring. Det vil si at når du svinger på rorene så svinger motoren også! Dette gjør flyet ekstremt villig til å svinge. Leveres som PNP versjon. Du trenger sender, mottaker, batteri og lader i tillegg.
Specs
Key Features
Needed To Complete
A 6+ channel DSM2- or DSMX-compatible transmitter capable of elevon mixing, dual rates, and exponential programming.
The E-flite Carbon-Z Scimitar is true satisfaction for the RC pilot who desires flight performance and adrenaline pounding excitement previously thought impossible from a conventional aircraft platform. The fantasy-scale Carbon-Z Scimitar, designed by world aerobatic champion Quique Somenzini, bursts open the performance envelope with an evolutionary tailless swept wing. At the heart of the advanced Carbon-Z Scimitar is a specially tuned Q-Power system harnessed inside a revolutionary single-axis, vectored-thrust propeller system. In combination with the precision of carbon rod hinged elevons and twin rudders, a refreshing level of maneuverability can be explored after less than an evening’s worth of assembly time.
Specs
Plane Type: | Sport Planes |
Experience Level: | Intermediate |
Power Plant Size: | 25-46 Electric |
Recommended Environment: | Outdoor |
Fuel Type: | Electric |
Wingspan: | 42.6 in (1080mm) |
Overall Length: | 35.0 in (889mm) |
Wing Area: | 565 sq. in. (36.5 sq. dm.) |
Flying Weight: | 4.40 lb (2.0 kg) |
Motor Size: | 32-size 1010Kv Brushless Outrunner (installed) |
Radio: | AR600 6-channel DSMX receiver (installed) |
Servos: | 5 digital high-speed, high-power sub-micro servos; 1 digital high-power metal-gear mini servo (installed) |
Trim Scheme Colors: | Red, black, and white |
CG (Center of Gravity): | 21.8-22.2 in (553-565mm) back from the airplane nose |
Wing Loading: | 17.9 oz/sq. ft. |
Prop Size: | 10 x 8 |
Speed Control: | 60-Amp Pro SB Brushless with Switch-Mode BEC (installed) |
Recommended Battery: | 4S 14.8V 30C 3200mAh LiPo (included) |
Retracts: | Optional |
Approx. Flying Duration: | 5 minutes |
Is Assembly Required: | Yes |
Charger: | 3-4S DC Li-Po Balancing Charger (included) |
Control Throw (Ailerons): | Low: 34mm up, 17mm down, 35% expo; High: 38mm up, 21mm down, 45% expo |
Control Throw (Elevator): | Low: 25mm up, 17mm down, 20% expo; High: 44mm up, 36mm down, 55% expo |
Control Throw (Rudder): | Low: 50mm right/left, 10% expo; High: 80mm right/left, 30% expo |
Spec_Assembly Time: | 5-7 Hours |
Spec_Experience Level: | Intermediate |
Spec_Fuel Type: | Electric |
Spec_Plane Type: | Aerobatic & 3D |
Spec_Power Plant Size: | 25-46 Electric |
Spec_Recommended Environment: | Outdoor |
Key Features
- Dual rudder and vectored-thrust control on the yaw axis
- Exceptionally strong and lightweight Carbon-Z structure
- Digital high-speed servos installed
- Single screw access to the electronic equipment
- Effective front and side cooling inlets with interior venting
- High-quality socket-head hardware throughout
- Distinctive color scheme for superior visibility
- Ready to accept optional E-flite electric retracts (EFLG110)
- All components, including the nose and control surfaces, are easily replaceable
Needed To Complete
