Parkzone Albatros D.Va WWI BNF fra www.smallsize.no
    Ikke helt upassende at denne dukket opp til omtale når Warbird Weekend nærmer seg.
    Link til Smallsize!
    Spesifikasjoner fra Parkzone:
    Compared to the Spartan look of most World War I airplanes, the smooth, rounded fuselage and flowing lines of the Albatros D.Va made it one of the more daring designs of its time. The ParkZone team has recreated this Western Front warrior with an impressive level of detail and equipped it with a potent 480-size brushless motor. Some of the more notable scale details include a molded recreation of the 180hp Mercedes D.IIIau engine, accurately modeled wing struts and a pilot figure complete with flying scarf.
Name:	Skjermbilde 2012-08-10 kl. 11.45.17.jpg
    • Spektrum™ AR600 DSM2/DSMX receiver, installed
    • 4-channel control – throttle, elevator, aileron and rudder
    • 960Kv 480 brushless outrunner motor, installed
    • E-flite® 30A Pro Switch-Mode ESC, installed
    • Servos, installed
    • Durable Z-Foam™ construction
    • Authentic Red Baron trim scheme
    • Machine gun, engine and pilot details
    • Includes steerable tail wheel and tail skid
    • Includes 3S 1800mAh 15C Li-Po battery
    • Includes 2- to 3-cell DC variable rate Li-Po charger
    • Compatible with the optional Sonic Combat Module AND the X-Port Adapter (HBZ4020 & PKZ1055 - both required and sold separately).
    Wingspan: 42.3 in (1070mm)
    Overall Length: 35.0 in (890mm)
    Flying Weight: 43.4 oz (1230 g)
    Motor Size: 480-size 960Kv Brushless Outrunner (installed)
    Radio: 4-channel (minimum) DSM2 or DSMX transmitter required
    Servos: 4 digital servos (installed)
    Prop Size: 10 x 8 (included)
    Speed Control : 30-Amp Pro Switch-Mode BEC Brushless ESC (installed)
    Recommended Battery: 3S 1800mAh 11.1V LiPo (included)
    Flaps: No
    Retracts: No
    Charger: 2-3 cell DC LiPo balancing charger (included)
    Minimum Age Recommendation: 14 years
    Experience Level: Intermediate
    Recommended Environment: Outdoor
    Assembly Time: Less than 1 Hour
    Is Assembly Required: Yes
    Bildekollasj fra Parkzone
ID:	591132Click image for larger version
ID:	591144Click image for larger version
ID:	591143Click image for larger version
ID:	591142Click image for larger version
ID:	591141Click image for larger version
ID:	591140Click image for larger version
ID:	591139Click image for larger version
ID:	591138Click image for larger version
ID:	591137Click image for larger version
ID:	591136Click image for larger version
ID:	591135Click image for larger version
ID:	591134Click image for larger version
ID:	591133Click image for larger version
      Modellen er bygd på en sløv halvtime i værste fall. Jeg fant frem manualen og delene og startet på.
      mvh
      Alf
Name:	ImageUploadedByTapatalk HD1346257611.510164.jpg
        mvh
        Alf
        • ArneH
          • Dec 2009
          • 1562
          Den ser jo spenstig ut til å være dobbeltdekker, fra den tiden. Skal bli artig å se hvordan den flyr.
          Vennlig Hilsen
          Arne Husby
            Re: Parkzone Albatros D.Va WWI BNF fra www.smallsize.no
            Er litt bakpå med monteringstråd pga sykdom så den fløy på wbw helgen som var. Flyr utrolig snilt og fint, som en trainer
            Alf
              Modellen er utrolig lett og grei å sette sammen.
              Ikke gjør som meg som ikke kikket i manualen....
              Monter undervingen før noe annet gjøres. Legg inn mottaker og koble til ledninger samt bind den opp så er det gjort. Noe upraktisk her er at man må ha av understellet delvis for å få av undre ving, litt kjedelig hvis man ønsker å stable bort modellen eller frakte den i mindre format.
Name:	ImageUploadedByTapatalk HD1346336670.696213.jpg
ID:	592272 Click image for larger version
Name:	ImageUploadedByTapatalk HD1346336688.256848.jpg
              Så installer undervingen og start deretter med å montere understellet.
              Her er det kombinert svart tilbøyd pianotråd og røde plastcover samt noen plastbiter som holder det hele på plass med skruer
              Bildene sier mer....
Name:	ImageUploadedByTapatalk HD1346336713.448884.jpg
ID:	592274 Click image for larger version
Name:	ImageUploadedByTapatalk HD1346336731.607528.jpg
ID:	592275 Click image for larger version
Name:	ImageUploadedByTapatalk HD1346336751.274918.jpg
              mvh
              Alf
                Øvre ving monteres så. Det følger med ytre og indre kabaner og de er laget med en liten hake slik at man legger de horisontalt med vingen, vipper denne haken fast i vingen og snur vingen opp-ned og skrur nedre del fast i kroppen. De ytre kabanene festes på samme måte i vingen med metallklips brukes for å feste de i øvre festepunkt.
Name:	ImageUploadedByTapatalk HD1346336884.083832.jpg
ID:	592277 Click image for larger version
Name:	ImageUploadedByTapatalk HD1346336900.813097.jpg
Name:	ImageUploadedByTapatalk HD1346336921.699327.jpg
ID:	592279 Click image for larger version
Name:	ImageUploadedByTapatalk HD1346336942.834950.jpg
                mvh
                Alf
                  Siste del er å montere høyderorsflaten og halehjul/skid bak som er valgfritt.
                  Haleflaten tres inn på plass og skrues fast med en skrue ovenfra. Må vri sideroret litt for å komme til. Linkene tilpasses i lengde og klipses på.
                  Jeg velger skid og ikke halehjul da det ser litt bedre ut. Halve festet er satt fast i kroppen så tar bare delen med skid og legger på plass og skrus fast med noen få skruer. Da er det bare å binde mot mottakeren, sjekke ror utslag og retning før flytur!
Name:	ImageUploadedByTapatalk HD1346507191.890447.jpg
ID:	592390 Click image for larger version
Name:	ImageUploadedByTapatalk HD1346507211.243881.jpg
Name:	ImageUploadedByTapatalk HD1346507232.527621.jpg
ID:	592392 Click image for larger version
Name:	ImageUploadedByTapatalk HD1346507253.221503.jpg
                  mvh
                  Alf
                    Modellen flyr nydelig, tåler egentlig ganske mye vind og er utrolig snill. Ingen tegn til flikk eller krevende av noen art.
ID:	593033 Click image for larger version
ID:	593035 Click image for larger version
ID:	593037 Click image for larger version
                    • ArneH
                      • Dec 2009
                      • 1562
                      Her går det unna! Du må ha en imponerende hangar etterhvert. Denne her så fristende kul ut, spesielt det du skriver om vind, og gode fly-egenskaper. Takk for gode og informative artikler!
                      Vennlig Hilsen
                      Arne Husby
