Har dere tro på denne?
Spørs jo hva du skal ha den til...
Although this is a UBEC and can handle up to 23v, its warning system is only designed for 2cell. Some would consider using a UBEC for 2cell as overkill, however it ensures a stable current, less heat and a higher amperage can be used.
This UBEC can be used with up to 23v input. If you use a 2 cell pack only, it will also warn you if your cells drop to 3v per cell.Espen Melby
Originally posted by kenzkyEr ikke det sånt lipo warner som beeper når cellene i batteriet kommer under et visst spenningsnivå?
Bare for 2s?Espen Melby
