Why discharging function on charger?
  • kjetillunde
    • Mar 2013
    • 23
    I`m looking at this iMax B6AC Charger for charging my 12v lead acid 7ah battery (I hope it will work for this?). When I look at the charger specs I wonder why there is a discharging rate? Can someone explain me what`s the reason with discharge function on charger?
    By the way, I`m new here and have no experience with lipo batteries and several cells.
    Originally posted by kjetillunde
    ...When I look at the charger specs I wonder why there is a discharging rate? Can someone explain me what`s the reason with discharge function on charger?
    Discharge is not used as widely in conjunction with lead-acid
    If you use LiPo/LiFe battery, this function is used to drain the battery to obtain a safe storage level.
    In conjunction with NiMH / NiCd batteries the discharge/charge function is used to "cycle" battery for maximize battery etc.
    Discharging is also used to test the battery performance by running a controlled discharge while it measures the amount of energy delivered.
    There's a lot more information about handling batteries in the eminent LIPO Guide thread here on MFN:
      • 6523
      Discharging is used for cycling Nixx batteries. Think thats just about it
        #4 Unapproved
        please charge you 12V battery on max 400mah
        Regards t.bakken
        • kjetillunde
          • Mar 2013
          • 23
          Glemte at dette var et norsk forum og jeg er jo norsk hehe.
          Takk for info.
          Regards t.bakken
          Hvorfor må jeg lade med maks 400mah på et 7ah batteri?
            Å det sier du nå......
            • kjetillunde
              • Mar 2013
              • 23
              Ja hehe, men takk for omtanken med translater og greier
              Hva er maks mA jeg kan lade 7,2A bly batteri på?
                #8 Unapproved
                Takk for info.
                Dette gjelder spesielt for gelebatteri bly 12V de tåler ikke mere en 500mah lading, så derfor 400mah,
                ha dette som en grunnregel for "små mopedbatteri" også.
                PS Hvert år kommer noen ned på modellflyplassen med sitt nye batteri som er ladet på 5A det virker ikke.
                • Brumm
                  • Apr 2008
                  • 1816
                  Re: Why discharging function on charger?
                  Haha.. priceless!
                  Logo 700 Xxtreme Vbar 5.3 Pro
                  T-Rex 700N DFC Vbar 5.3 Pro
                  T-Rex 500 DFC Vbar 5.3 Pro
                  • flarssen
                    • Jan 2005
                    • 1842
                    Det er ingen 'h' i enheten for strøm.
                    Fred Larssen
                    • lupus49
                      • May 2008
                      • 647
                      Om man har et toppladet lipo som skal lagres, er det raskere å "tømme" det ved hjelp av en motor eller pære, for så å bruke laderen til å få opp nivået til lagringsspenning. Laderen trenger veldig lang tid for å lade ut lipo.
                      Flisespikkeri er gøy!
                      Dyrøy MFK
                      http://rolv.info
                        #12 Unapproved
                        500 mAh ~ hvor mye strøm som kan tilføres ett batteri pr time
                        Dvs den vedien du stiller inn på laderen din.
                        Terje
                        • bth
                          • Dec 2003
                          • 1638
                          Terje
                          500 mA er ladestrømmen.
                          500mAh er kapasiteten du har tilført et batteri etter en time ved 500 mA lading.
                          500 mAh kan derfor også være 250 mA ladestrøm i 2 timer, eller 50 mA ladestrøm i 10 timer.
                          Bfight 210
                          De Havilland DH 2 skala 1/5,3
                          Phoenix RC Club
