Realflight G3??
  • Dr.Phil
    • Jul 2004
    • 322
    Realflight G3??
    Ser på http://www.realflight.com/ at Realflight G3 er på vei!!!
    Utrolig spent på hvordan denne blir. De har vel stressa litt nå når alle bare snakker om XTR
    Philip
    www.airheads.no
    Hobby24.no
  • Dr.Phil
    • Jul 2004
    • 322
    Fra RC Universe :
    Great Planes Mfg. RealFlight Generation 3
    Over 2500 square miles of flying fun!
    The largest flying regions of any simulator - each created from hundreds of MB of satellite imagery and digital elevation data. Modelers may run out of fuel before they run out of new scenery in a flying site!
    Positively THE most realistic R/C simulator ever produced!
    Over 10 unique airfields to fly at!
    Backgrounds that are anything but static!
    Objects accurately rendered in 3D!
    Generation 3 goes far beyond the 2-dimensional, "billboard"-look of other simulators. It's a living, breathing environment - fliers can immerse themselves in the realism! Trees sway in the background; clouds on the horizon follow the path of the prevailing winds; glare increases and subsides in relation to the position of the sun. Background objects even reflect off of the aircraft.
    The incredible flight performance of new RealPhysics 3D!
    RealFight Generation 3's new RealPhysics 3D physics engine was put through demanding tests and trials by world-class modelers. They all agree that aircraft on G3 fly more realistically than ever before - in fact, this simulator sets unprecedented standards for accuracy in exciting high alpha (3D) flight!
    An easier and more powerful Aircraft Editor!
    An almost infinite number of changeable parameters!
    Any modifications that a pilot wants to make to a plane are graphically represented on the wire-frame model, and reflected instantly on-screen.
    Break-apart aircraft!
    As is the case in real R/C flying, modelers may shear a wing off of their aircraft if they are too careless. The aircraft continues its flight, while accurately reflecting the parts lost!
    Unparalleled collision detection!
    Faster and more accurate than ever before!
    Unlike other simulators that have just a few collision points, Generation 3 utilizes a triangle-to-triangle collision detection system that "blankets" the entire aircraft with a network of collision detection points.
    Superior wind modeling!
    The wind field on G3 features 5 components: terrain-shaped, convection, macro-turbulence, micro-turbulence and global - to account for even the smallest detail! As winds collide, the strength and direction vary accordingly, and airplanes and gliders will feel the "bump" of a slope lift as they approach the top of a mountain or hill.
    Top-notch teaching!
    The Virtual Flight Instructor (VFI) has been expanded and enhanced to include additional maneuvers for pilots of all skill levels. Experienced modelers will be able to learn high-alpha 3D aerobatics from world-class pilots!
    Airport creating that's easy to use!
    More objects to choose from!
    With "drag-and-drop" simplicity, modelers can create entirely new airports using the mouse and just a few keyboard strokes.
    More aircraft choices than ever before!
    Almost FOUR DOZEN unique designs to choose from!
    From park flyers to 3D aerobats, slope soarers to Reno racers, plus helis and gliders, there's a wide variety of models to appeal to every modeler's tastes.
    A 360° "walk-around" preview option!
    After the selected plane appears on screen, it revolves continuously.
    Using the mouse it can be viewed from the top or bottom as well. When changing trim schemes, modelers immediately see the alternate model in the preview box.
    One-click installation!
    Even the novice computer user will be able to quickly install RealFlight G3 with the customized one-click installer!
    The InterLink Plus controller is new and improved!
    Now with Multi-Mode feature!
    The Multi-Mode feature on the InterLink Plus controller allows modelers to connect an additional InterLink or standard radio transmitter to the simulation! A push-button on the InterLink Plus controller allows for rapid, keyboard-free model reset.* *The InterLink Plus controller can als o be used as an interface with most 4-10 channel, FM or PPM-selectable radios which include a trainer jack. For additional information, visit the RealFlight website at www.realflight.com.
    Split-screen capability!
    G3's split-screen capability takes advantage of the InterLink Plus'
    multi-mode function. Multiple players on the same PC can fly together or conduct personalized training sessions.
    Complete Add-Ons* compatibility!
    Generation 3 is compatible with all five volumes of RealFlight Add-Ons, expanding the system's capabilities even more!
    The most popular features from Generation 2 have been retained on G3:
    * Multi-Cam* picture-in-picture viewing
    * Adjustable point of view
    * Multiplayer online fun
    * Heads-Up NavGuides*
    * Playback and Recordings
    * Competition/Events such as limbo, pylon racing and spot-landing
    * Much, much more!
    For system requirements or additional information, visit the RealFlight
    website at: www.realflight.com
    GPMZ4400 RealFlight Generation 3 Mode 2
    GPMZ4401 RealFlight Generation 3 Mode 1
    Retail $299.99
    Street 219.99
    DUE IN STOCK MID-NOVEMBER
    Philip
    www.airheads.no
    Hobby24.no
