Multiplex PROFI TX16
    På lager hos AutoPartner i alle fall: http://www.autopartner.se/multiplex-...904-c-438.aspx
    The PROFI TX M-LINK sets new standards in its class, with 2.4 GHz transmission technology and numerous innovative and pioneering features:
    • Integral aerial technology (IOAT) (Integrated Optimized Antenna Technology): integral aerial with enhanced radiation pattern, optimised for model control: double the signal density transmitted to the model, offering a significant enhancement in security.
    • Secure, ultra-fast signal transmission
    • Clean, clearly arranged menu structure
    • LiFe battery (25 hours transmitter time) with battery management
    Flexible ergonomics allow the owner to fine-tune the system
    individually and accurately to meet his individual needs
    • For tray-mounting, use with hand-rests or neckstrap
    • Swivelling stick units
    • Conveniently located side-mounted proportional controls and optional switches
    • Carefully positioned digital trims for easy access
    The clean, clearly arranged menu structure provides:
    • Programs for power models, gliders, jets and helicopters
    • QuickStart
    • Languages: German, English, French, Italian, Spanish
    • Up to 200 model memories
    • Unlimited model memory data can be saved, backed up and managed on a PC
    • Up to sixteen fully proportional servo channels
    • Unrestricted servo channel assignment
    • 100% individual configuration of transmitter controls and switches
    • Flexible mixer structure: five mixers per model, can be used as many times as required, seven mixer inputs per mixer, curve mixer
    • Seven-point collective pitch / throttle curve for helicopters
    • Three stopwatches
    • Transmitter battery management: display of residual charge quantity (mAh) and residual operating time (hh : mm)
    • Display of up to sixteen telemetry values
    • Innovative flexible circuit board system minimises connector count for greater security
    • Wireless Trainer system with individual control function transfer
    “Premium Edition” contents: Limited edition of 555 units
    • PROFI TX16 M-LINK “Premium Edition” transmitter with sixteen channels and 200 model memories.
    Special features: numbered transmitter, black chrome colour aluminium stick tops, expanded with six switches and two digi-adjusters
    • Numbered PROFI TX16 M-LINK “PremiumEdition” VIP card with “four years special service”
    • RX-16-DR pro M-LINK “PremiumEdition” receiver
    • “Premium Edition” Souffleur
    • “Premium Edition” GPS
    • “Premium Edition” voltage sensor
    • “Premium Edition” aluminium transmitter case
    • Numbered “MULTIPLEX PROFI TX” chronograph
    • USB lead (PC interface, charge lead)
    • 230 V mains charger PSU
    • USB interface lead (UNI)
    • Large, hinged, superbly legible 4” LCD monitor
    • Earphone socket
    • Illuminated “warning monitor”
    • Digital trims, flight phase specific
    • Vibration alarm
    • Maximum operating time 25 hours (LiFe transmitter battery)
    • Direct menu access buttons
    • Integral handle
    • 3-D programming wheel (push / turn)
    • Two proportional sliders+ 2 markers
    • Ideally positioned sidemounted sliders and switches
    • Completely unrestricted installation of control elements (optional switches, buttons, rotary knobs)
    • USB socket (model data transfer, firmware updates, integral battery charger)
    • IOAT (Integrated Optimized Antenna Technology) maximum transmission power, full range, optimised radiation pattern)
  • Leeds
    • Feb 2011
    • 168
    Hei, er det noen her med erfaringer på Profi Tx 9, 12 eller 16? Nå er jo firmware v2.28 sluppet og programmering av sensorer kan man gjøre direkte på radioen og ikke via pc slik som man måtte før samt masse annet. Har Evo Pro 16 nå og Profi 16 i posten.
    Pilot RC 29% Sbach 342 m DLE-55
    Phoenix Mustang P51D m DLE-55
    Blackhorse Spitfire Mk IX m O.S GF40
    Multiplex Minimag
    Multiplex Razzor
    Multiplex Rockstar
    Multiplex Shark
    Top Flite Piper Arrow O.S GT15 (ikke ferdig)
    Multiplex Profi TX 16
    Byggeblogger:
    http://www.lyngstad.synology.me/blog/index.php?
    • smsyak
      • Oct 2010
      • 90
      Etter å ha fløyet med profi 3030 siden 1987, har jeg nå brukt Profi TX16 i ca halvannet år nå. Fantastisk radio på alle måter bortsett fra selve kassa som jeg mener kunne vært litt tightere. (Kunne gjerne vært skrudd sammen i stedet for hurtigåpning som virker litt slarkete. Den er også litt stor og tung). Programmeringsmessig fantastisk.
      • Leeds
        • Feb 2011
        • 168
        Er det flere enn deg og Haagen som bruker Multiplex i Tromsø? Kun 4 her i Harstad men håper jo på flere
        Multiplex Minimag
        Multiplex Razzor
        Multiplex Rockstar
        Multiplex Shark
        Byggeblogger:
        • Leeds
          • Feb 2011
          • 168
          Noen som vet om man kan kopiere inn alle modellminnene fra EVO til Profi for å slippe å legge alt inn. Tenker da via Launcher softwaren.
          Multiplex Minimag
          Multiplex Razzor
          Multiplex Rockstar
          Multiplex Shark
          Byggeblogger:
          • Wiker
            • May 2003
            • 195
            Ja, æ Bor ikkje akkurat i Tromsø da, men det e der æ e medlem.
            Tro ikke du kan kopiere modeller fra Evo to Profi, du må nok legge inn manuelt. Men oppsette er likt, så i prinsippet tror jeg man kan flytte de samme tallene fra Evo og legge dem inn på samme sted i Profi.
            Veldig fornøyd med min Profi TX. Har flydd i 3 timer så å si i et med Profi rundt nakken uten å merke noe til at den var tung. Passer kanskje ikke så bra hvis man flyr håndholdt Playstation-style, men med nakkestropp er den verken stor eller tung.
            Like at antenna er helt integrert inni senderen. Over 30 timers flytid på en lading. Fint med brakettene for nakkestropp som enkelt foldes ned å skyves inn i senderen (så nå trenger jeg ikke senderpult lengre). Dette uttrekkbare bærehåndtaket trodde jeg bar bare fjas, men jeg bruker det faktisk hele tiden – veldig grei måte å bære radioen på istedenfor å ha den dinglende rundt halsen.
            Liker Profi bedre enn min gamle 4000, selv om 4000 har noen flere triks i oppsettet. Profi er raskere å stille inn en ny modell (samme som på Evo), mens 4000 var litt mer omstendelig.
