Mejzlik 23x8 evo carbon propell
  • bardp
    • 2473
    Skulle bestille en Mejzlik 23x8 propell for og bruke på en DLA 56 men den var det tomt for. De hadde omidlertid denne MEJZLIK 23X8 EVO CARBON PROPELL. Noen som hvet hvilken propell det er og hva som skiller den fra en vanlig propell.
  • Moki
    • Oct 2008
    • 331
    23x8 EVO Carbon Propeller
    Mejzlik props are among the quietest props available. Vertical performance is spectacular along with excellent down-line braking.
    •EVO props are lighter than standard
    •EVO Light are the lightest Mejzlik props
    These high performance props from the Czech Republic feature hollow blades fabricated from unidirectional and bi-directional carbon fiber and epoxy. While very light, they are super strong, with a solid center hub area allowing them to be drilled for multi-bolt hubs. The finish is a beautiful high gloss, clear epoxy gel-coat over black woven carbon fiber. All are factory balanced.
    Hasse Øhlund.
    • Moki
      • Oct 2008
      • 331
      Propellers
      Carbon props Mejzlik are the most popular props for the most of the top large remote controlled acrobatic model pilots. It is almost a rule that eight out of every ten pilots of the most prestige world acrobatic competitions are using Mejzlik’s props. Be one of them! Be convinced that Mejzlik’s props are supporting higher performance but low noise level of propulsive unit as well as unique safety run. Besides, they are really nice!
      When we design our propellers we taking the advantage of many years experience of our specialists as well as knowledge of costumers. Last but not least we are keeping up to date with all aerodynamic and composite technologies, with that is helping us cooperation with professionals from top research and university working stations in Czech Republic.
      Mejzlik’s props are made only from the high quality carbon fabric and rovings, filled with epoxy resin made suitable for our needs. During the making procedure are our specialists following exact technological steps, including not only quality and amount of material but also temperature and other physical aspects of working environment.
      Props labelling:
      XX x YY – diameter of prop in inches x pitch of prop in inches
      3B – three bladed prop
      N – prop with narrower blades
      W – propeller with wider blades
      S –* props with scimitar-shaped blades
      TH – prop with very thin profile of blades
      EVO – our newest type of props with new profile
      L – lightweight prop with composite torsional interstice in leading edge of blade
      Label N or W is connected to the basic, standard execution. It means in general features, if you need to load down an engine, but nearest prop with higher diameter is too “heavy”, it is possible to use prop “W” with wider blades. And other way round if you need to reduce the load on the engine, use the one with narrower blades.
      Scimitar shaped props should reduce the level of noise even more. As other aspects are counted, it is recommended to verify real benefit.
      Props with TH label are equipped with very thin profile. TH props were originally designed for electric motors, as we discovered thanks to elaborated construction and quality, they could be without any problems used with gas engines as well
      EVO props are modern, light props with new, more efficient shape of blade and a new profile. This combination brings a sinking of noisiness, increasing of efficiency and more power for your machine.
      Lighter props labelled “L” are made by new procedure where is between the top and the bottom of propeller’s shell glued a prepared torsion box. They guarantee great strength and toughness of the blade with lowest possible weight. Namely: Props L are from 20% to 30% lighter than the standard version.
      Hasse Øhlund.
      • bardp
        • 2473
        Da skulle vel den EVO propellen fungere utmerket.
        • Kenolang
          • Jul 2010
          • 2530
          EVO propellen er rå.
          Den bråker litt mer, drar mye mer og oppnår samme turtall som S-propellen
          Ikke noe å lure på, kjøp!
          EF Yak-54. 110"
          EF MXS 83"
          GB Yak-55 2,2m
          Autopartner.se
            Re: Mejzlik 23x8 evo carbon propell
            Avhenger vel litt av naboer? Trenger du støysvake gode propellere så er Engel Silent ett godt alternativ, koster dog litt..
            Alf
            • bardp
              • 2473
              Nå er nermeste nabo til stripa en skytebane så propelstøy er ikke noe stort tema. Klarer uansett ikke og bråke like mye som de som flyr 3D med store helikoptre.
