Elektromotor til sback .46-55
  • kolaf
    • May 2006
    • 103
    I have been out testing my brand-new sbach, and I am happy to say that it is still in one piece. However, it quickly turned out that the motor solution was due week. Currently I have a 6S battery connected to a 600Kv motor. We first tried a 12x8 propeller which was not really able to get any comfortable it off the ground. After upgrading to a 13x7 propeller I managed to do my maiden flight without trouble, but I hesitate to run full speed (which is 11,000 rpm, and makes the tips break the speed of sound). I think it is evident that I need to reduce the size of the battery or the kv of the motor. What do you think? The model weighs around 3 kg.
    Currently I'm thinking of going for an motor around 350-400Kv with a 16x8 or 16x10 propeller. This should give me around 1 kW of power, 5.5 Kg thrust, and around 55A. Does this sound okay?
    Please feel free to respond in Norwegian.
    I have electro in a 40size 3d plane. there i have a 660kv motor. running on 5s. and using a 14x8 prop. that is working werry well
    • bth
      • Dec 2003
      • 1639
      Ser ut til at du trenger en motor med disse dataene:
      Power 60 Brushless Outrunner Motor, 400Kv
      Key Features
      Equivalent to a 60-size glow engine for 6 to 10 lb (2.7 to 4.5 kg) airplanes
      Ideal for 46-size 3D airplanes up to 7 lb (3.2 kg)
      Ideal for models requiring up to 1700 watts of power
      High-torque, direct-drive alternative to inrunner brushless motors
      Includes mount, prop adapters and mounting hardware
      External rotor design—6mm shaft can easily be reversed for alternative motor installations
      Slotted 14-pole outrunner design
      High-quality construction with ball bearings and hardened steel shaft
      Quiet, lightweight operation
      Overview
      The Power 60 is designed to deliver clean and quiet power for 60-size sport and scale airplanes weighing 6 to 10 pounds (2.7–4.5 kg), 46-size 3D airplanes up to 7 pounds (3.2 kg), or models requiring up to 1700 watts of power. It’s an especially good match for Hangar 9 .60-size warbirds like the Corsair 60 (HAN2575), P-47D Thunderbolt 60 (HAN2975), P-40 Warhawk 60 (HAN2850), P-51 Mustang 60 (HAN2375), P-51 Miss America 60 (HAN2775) and .46-size 3D planes such as the Hangar 9 Funtana 40 (HAN1975) or Seagull Harrier 46 (SEA3025).
      Product Specifications
      Type: Brushless outrunner
      Size: Replacement for 60-size glow engines
      Bearings or Bushings: One 6 x 15 x 5mm Bearing, and Two 6 x 12 x 4mm Bearing
      Wire Gauge: 14
      Recommended Prop Range: 14x8 to 16x10
      Voltage: 18.5 to 28.8
      RPM/Volt (Kv): 400
      Resistance (Ri): .06 ohms
      Idle Current (Io): 2.70A @ 10V
      Shaft Diameter: 6mm (.24 in)
      Overall Length: 62mm (2.40 in)
      Weight: 380 g (13.0 oz)
      Overall Diameter: 50mm (2.00 in)
      Diameter: 50mm (2 in)
      Length: 62mm (2.4 in)
      Continuous Current: 55A
      Maximum Burst Current: 65A (15 sec)
      Cells: 16–24 Ni-MH/Ni-Cd or 5–7S Li-Po
      Speed Control: 60A brushless
      Bfight 210
      De Havilland DH 2 skala 1/5,3
      Phoenix RC Club
