Best temperatur for Oracover?
  • canuck
    • Sep 2005
    • 110
    Jeg hadde tenkt å gå over oracoveret på en ny modell jeg har kjøpt siden det er ei blemme her og der. I anledningen kjøpte heg et Protech Turbo Sealing iron. Vet noen hva den optimale temperaturen for Oracover er?
    Are Barstad
  • Per
    • 243
    Hei hei.
    Jeg bruker ca 130 grader for å stramme den opp, 160-170 grader for å feste og forme den rundt kurver.
    • -Exlex-
      Forhandler
      • Nov 2003
      • 793
      I følge produsent reagerer limet allerede ved 100 grader , max temp er 250 grader
      -Exlex-
      Thor Arne Jensen
      ____________________
      : -Exlex-
      : Thor Arne Jensen
      • Celtic-Griffin
        • Oct 2004
        • 873
        Firstly, it is important to know that opaque Oracover has a much higher melting point than the transparent (low temperature) type.
        To re-tighten the existing covering on an ARF, it is often better to use a hot air pistol, providing the hot air stream is not concentrated on one small area - keep the hot air pistol in motion over the film surface all the time.
        If a hot iron is used, a soft cotton glove is recommended to prevent scratching of the fine gloss surface of the film.
        Bubbles are most often the result of trapped air and a pin prick into the bubble before applying heat will allow this air to escape.
        In general, an iron is used to seal film covering around the edges and the warm air pistol to shrink the film over the underlying structure.
        The temperatures given by the manufacturers are a guide, only the actual temperature for a specific job should first be approached with caution the first time and when established, the position may be marked on the tool for future reference.
        To calibrate the temperature scale on the iron, a drop of water on the iron whilst the iron is heating up will indicate 100C when the water begins to boil.
        Be particularly careful in areas where two film covers join and overlap, here it is very easy to apply a little too much heat with the result that the two colours shrink back and separate, leaving the underlaying structure in daylight.
        It all sounds very difficult, but in reality quite straight forward if a little caution and patience is used...
        Ken Bates
        Never Mind the Label
        • Alfalfa
          • 988
          Helt enig i at det er best å bruke varmluft for å rette ut filmen, men ved overlapping mellom opaque og transparant film er det nesten umulig å få det pent uten strykejern. Her greier man sjelden å være forsiktig nok med varmen..
          Legg et kopphåndkle over trekket og bruk strykejernet forsiktig i sømmene, så blir det pent!
          • Celtic-Griffin
            • Oct 2004
            • 873
            We are on the same wavelength, Alfalfa....
            Ken Bates
