Jeg går og sikler på en Impact....
Snakket med Geir Flesche, han opplyste om at det var flere i norge som hadde bestilt, Hvor mye kom byggesettet/flyet på ferdig levert ?
8000 kr?
Hva skal dere ha i nesa 140rx, 3W28, SM30, ZDZ40, elekro ?
Har noen prøvd besinmotorer i F3A? blir det for tungt ? Elektro virker som det er framtiden, men foreløpig blir det rel. dyrt. Mitt viktigste mål er hva som vil gi best egenskaper..
Fant masse på RCU har lagt ved linker for de som er intersessert
Jason Schulman vant F3A i USA med dette setupet..
Here is the set-up I used at the Nats:
Airplane: Composite-ARF Impact
Radio: Futaba 9ZAP
Servos: Futaba: Ail: 9151, Elv: 9650, Rud:9151
RX: Futaba 148 DP
Motor: Hacker C-50 14XL 6.7:1 Acro
Controller: Master-90-Acro
Prop: APC-E 22x12
Batteries: Thunder Power 10S3P 6000 mAh ($325 a half-pack, $650 for the 10S3P)
Duralite 6V reg with 730 2-cell
Kirby's Kustom (last minute) Graphics
Wt: 11lbs RTF
The airplane was finished just before I left for the Nats, but having flown the Rev-Pro all year, it was easy to get adjusted to the Impact. It actually performed better than the Rev-Pro, so it gave me a bit of a confidence boost once I had it set-up. The plane was 2.2 ounces over 11lbs when I left home, but I used a Tru-Turn spinner instead of the supplied Carbon one, and had a bit of extra "junk" here and there. I do have another Impact here that I will stick my OS 140 EFI (or maybe 160 FI) but not until November or so after all the big plane contests are done with.
_____________________________
JAS composite-arf.com/ar/Catalog?cat=27">www.composite-arf.com/ar/Catalog?cat=27
http://www.rcuniverse.com/forum/Comp...1732531/tm.htm
http://www.rcuniverse.com/forum/ZDZ_...2289936/tm.htm
Er det noen som har prøvd denne motoren SM30 ?
8000 kr?
Radio: Futaba 9ZAP
RX: Futaba 148 DP
Prop: APC-E 22x12
Wt: 11lbs RTF
