Bantam E-Station til Norge
  • Bantam E-Station til Norge
    Bantam of Korea have established an enviable reputation for quality electronic products internationally. For 2007, Griffin Models has added a number of these products to the Griffin portfolio. The following products for starters are now available:
    BANTAM E-STATION CHECKMASTER
    Servo Tester - 900~1500~2100us
    Measure Pulse - RX channel pulse (us)
    Watt Meter - 0.1 - 100.0A Volts/Watt/mAh
    Tachometer - 1~6 blades to 34000RPM, 10 data memories
    Tacho+Wattmeter
    Temperature Sensor - 0 to 250 degrees C
    Battery Checker/Discharger
    Battery Check/Discharge Load - 100 to 1000mA
    Inboard Battery NiCad 4.8V, 900mAh
    Weight - 350gram
    Dimension - 113x80x28
    BANTAM E-STATION 301 CHARGER
    Operating Voltage - DC 11~18 volts
    NiCad/MH - 1~14 cells
    Li-polymer - 1~5 cells
    Pb - 2~12 volt
    Charge Current - 0.1~5.0A
    Discharge Current - ~0.1-1.0A
    Weight - 350gram
    Dimension - 113x80x28mm
    BANTAM E-STATION 902 CHARGER
    Idling Current - Ca.100mA
    Charge/Discharge Power - max. 200/50W
    NiCd/MH - 1~32 cells
    LiLo/LiPo/LiFe - 1~12 cells
    Pb - 2~40V
    Charge Current - 0.1~9.9A
    Discharge Current - 0.1~9.9A
    Battery Data Memories - up to 10
    Weight - 1050gram
    Dimension - 160x148x60mm
    These products with their beautiful brushed aluminium cases exude quality and in addition to Schultz's Chamelion are now recommended by Flight Tech for maintenance of their FlightPower EVO20 and Duralite batteries. Browse the Bantam website for further details of these and other Bantam products and/or contact Griffin at pal@griffin-models.com for details and prices.
    Ken Bates
    Never Mind the Label
