BeskrivelseF00015-A KDS Flymentor 3D Balancer & PPC program card,for Heli Gyro,Trex 450 500 uåpnet i originalforpakning. Her får du altså både Flymentor-systemet og programmerer for mindre enn det bare Flymentor koster på nettet.Massevis av videoer og tester av systemet på youtube. Sjekk denne for eksempel:
system has multiple applications from stabilizing your aerial photography platform to acting as an electronic insurance policy when you trying out some crazy 3D or flying that high-roller scale turbine machine!Features:A new type of sensing process provides reliable geographical positioning, completely independent of the visible horizon.The built-in CCD sensor can catch the ground picture to compare, and prevent the helicopter from drifting. You can adjust the working status of Flymentor by using an AUX Channel. A awitchable gain system offers three different positions: Off, Stabilisation and Position-holding mode.It also includes programming for heading lock gyro outside setting and Swashplate mixer. You can control the sensitivity and mode of gyro by a GEAR/AUX Channel.The electronics support helicopters with 3-Servo 120-degree swashplate, or 3-Servo 140-degree swashplate, or 4-Servo 90-degree swashplate and 4-Servo 90-degree+45-degree swash plate.The system also compensates for attitude stabilisation in inverted flight.You can program the Flymentor by computer USB adapter.If you use FM/PPM radio equipment, Flymentor will make the aileron, elevator and tail servo back immediately as a failsafe. The pitch will remain in the final signal position. And Flymentor will switch to position mode automatically. The sensitivity is 70%.Description Flymentor 3D is a stabilization unit that not only stabilizes the rc helicopter against external inputs such as wind turbulence, but will also hold the helicopter in position. The Flymentor uses both gyros and and a CCD imaging device to help stabilize the Helicopter. The gyros stabilize orientation and the CCD holds position with respect to the ground. Let go of the controls and the Flymentor will upright your helicopter (of course within reasonable limits!). This system has multiple applications from stabilizing your aerial photography platform to acting as an electronic insurance policy when you’re learning to fly better. Automatically Hovering in a Fixed Position - KDS Flymentor 3D Stabilizing SystemThe KDS Flymentor 3D contain 3 components, the Flymentor Mixer, a CCD Camera and a 3-Axis Gyro. The system act as a Auto Pilot, it will only steps in when you don't give any input, but once you move your hands on the control sticks again, the system will de-activate and let you take charge again, pretty amazing, isn't it? Just like a real Auto Pilot when you need a break. The system provides 2 main features, Stabilizing Mode and Positioning Mode.What is Stabilizing Mode?Under this mode, there will be solid red and green light on the Flymentor Mixer, the CCD will not be working, only the 3-Axis Gyro is working. When you play the helicopter outdoor, there is wind, right? When wind pass thru the helicopter, it will push the helicopter and making it up side down, you will need to adjust the control sticks constantly to prevent this from happening. By using the Flymentor, it will automatically correct the cyclic servos and keeps the helicopter always in horizontal mode. Thanks to the 3-Axis gyro, it can work all around 360 degree correction.What is Positioning Mode?In this mode, there will be solid green light on the Flymentor Mixer, the CCD Camera and the 3-Axis Gyro are both working. The CCD Camera will constantly taking pictures of the ground, and compare each frame, to see if the helicopter is drifting, then it tells the Flymentor Mixer to give correction to all cyclic servos. Resulting the helicopter will stay in a Fixed position. The concept is basically an Eye watching the ground and make adjustment, kinda like a real human. But note that the system is not hooked up with the throttle, the attitude of the helicopter is still in your control.Specifications
imensions (Length x Width x Heigth): 145 x 60 x 15mmCable Length: 400mmNet weight: 74gPackage Included:1. KDS Flymentor Mixer2. KDS Flymentor CCD Camera3.KDS Flymentor 3-Axis Gyro4.CD with Installation Guide and Software5.USB Cable
More...
More...
