Eflite – EDGE 540 BP ARF
  • RSS
    • Dec 2013
    • 6055
    - Stiv og lett balsa/finer konstruksjon, kan fly svært sakte - Komplett fly inkl 2 stk batterier og Spectrum mottager - All elektronikk passer godt til flyet og kommer fra Hobbycity.com(unntatt mottager). - Flyet er ferdig montert som vist på bilder og har ca 10-12 turer i ”loggen” - Kan sees/hentes på Fitjar, sendes ikke. Produsentens beskrivelse: Overview The Edge 540 BP 3D combines the sturdy construction of a balsa/lightweight plywood airframe with the uninhibited 3D capability of a lightweight profile park flyer. It’s all made possible by its intelligently engineered, open structure design that keeps weight to a bare minimum while providing all the structural integrity of a real wooden airframe. This feather-light construction, combined with a high-output brushless motor, will provide spine-tingling 3D and freestyle performance that will let you really push the limits. And it comes from the factory 90% built and covered in genuine UltraCote, so you can be up and flying in no time. Product Specifications Wingspan: 35.5in (900mm) Overall Length: 36.5 in (930mm) Wing Area: 410 sq in (26.5 sq dm) Flying Weight: 15-16 oz (425-455g) Motor Size: Park 400 or Park 450 Radio: 6 channels (for proper mixing) Servos: 4 sub-micro Trim Scheme Colors: Ultracote Lite Transparent Clear (HANU964), Ultracote Lite Transparent Yellow (HANU967),Ultracote White (HANU870),Ultracote True Red (HANU866) CG (center of gravity): 4 1/2-inch (114mm) Prop Size: 11x3.8 slowflyer (park 400) or 12x6 E (Park 450) Hardware Included: Yes Speed Control : 20A Brushless Recommended Battery: 11.1V 3-cell 910-1320mAh Li-Po Control Throw (Ailerons): 1" (25mm) with 20% Expo on Low or 2" (50mm) with 40% Expo on High Control Throw (Elevator): 2" (50mm) with 20% Expo on Low or 2-3/4" (70mm) with 45% Expo on High Control Throw (Rudder): 3-1/2" (89mm) Left and Right Scale: Park Flyer Approx. Assembly Time: 3-4 Hours 6-channel transmitter (for proper mixing and dual rate capabilities) Micro receiver 4 sub-micro servos Motor 20A Brushless ESC Propeller Battery & Charger
    More...
