Hitec HS-5685MH HV 2S LiPo x10
  • RSS
    • Dec 2013
    • 6055
    Servo kun montert i fly! aldri blitt flyd med.10STK servoer selges.Servo fra Hitec i standardstørrelse som man kan koble direkte på 2S LiPo. Med en spenning på 7,4V drar servoen 12,9kg på 0.17 sek. Servoen har metallgir og doble kulelager for presisjonens skyld.The HS-5685MH High Torque HV Metal Gear servo was designed to run on a 2-cell 7.4V LiPo battery to give you extra torque and speed. Featuring a heavy-duty metal gear train and our exclusive programmable digital circuit for reliable, durable performance, these servos can be used in a wide range of applications. Our affordable digital sport servos are the perfect companion for 1/10th to 1/8th scale on- and off-road vehicles, as well as larger sport helicopters and large scale aerobatic aircraft up to 25-percent. Features •Programmable Digital Circuit •Heavy-Duty Metal Gear Train (MK first gear) •7.4V Optimized Motor •Dual Ball Bearing Supported Output Shaft Programmable Features Include•Dead Band Width•Direction of Rotation•Speed of Rotation (slower)•End Points•Neutral Points•Fail Safe On/Off•Fail Safe Point •Motor Type: 3 Pole Ferrite •Bearing Type: Dual Ball Bearing •Speed (6.0V/7.4V): 0.20 / 0.17 Second @ 60° •Torque oz./in. (6.0V/7.4V): 157 / 179 •Torque kg./cm. (6.0V/7.4V): 11.3 / 12.9 •Size in Inches: 1.6 x 0.8 x 1.5 in •Size in Millimeters: 40.6 x 19.8 x 37.8 mm •Weight oz.: 2.1 •Weight g.: 60g Ring for prisNy pris 405kr pr servo
    More...
